Question about Whirlpool Duet GHW9150P Front Load Washer
Detergent door will not open? - Whirlpool Duet GHW9150P Front Load Washer
  • Gary Davd
    Gary Davd May 11, 2010
    THIS IS A WASHING MACHINE DUET TYPE RIGHT??
  • Gary Davd
    is the cycle finished?? did you move the tab over??
  • 770 Answers
This is a free service where you are asking (posting ) a question Myself and others have decided to help you and we only charge for prem services like chat and I need an answer now !! but we spend our time helping people like you because we like to.. There is nothing for us to delete what you have typed here is all that is posted...If you are that paranoid then maybe dont post anything here and just pick up a phone and call a local service tech....GEEEZZZZZZ
Posted on Jan 26, 2008
I dont want to pay soemone just to ask a question, so you can take me OFF of you mailing list and delete my loggin information
Thank You fopr removing me
Karen
    President:
  • 1,314 Answers
You may be able to remove the top panel and remove the screws securing the dispenser assembly to the frame then either slide the dispenser back or reach under and release it by pushing the tab this is not a normal problem so there really is not a normal solution
Where do you put the dish wash detergent for my dish washer!
Hi, for most dishwashers the detergent cup is behind a little door in the door of the dishwasher.. snap open the door and place the detergent in the cup while the door is open and down, then close the little door and then close the dishwasher door...
then you are ready to roll...
DishwasherRepair Problem Detergent Cup does not Open
heatman101
Sep 19, 2010 | Dishwashers
Cannot unlock door lock
Can't help on the lock release, but will say that OFTEN the detergent will not dump if it is filled too much. Leave a little space.
Dec 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Dishwasher detergent door won't release soap
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
l
Apr 06, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Inside detergent compartment door will not open during cycle
to much detergent clean it out and start over
Jan 31, 2009 | Dishwashers
The cover of detergent dispenser does not open..
switch back to using powdered soap, sometimes what happens is hte tablets your using are actually to big for the dispensor door and too much pressure is put againt the actual door so when its triggered to open there too much resistance nad cannot open, sounds silly bu have actually sen it in action. and liquid detergent tends to clog or gunk up hte door spring assy, powdershte best detergent to use for d/w's
Mar 20, 2008 | Kenmore 24 in. 16534 Built-in Dishwasher
Detergent Door not Opening
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. In case it will not solve your problem, you should replace the wax motor that operate the cup door. Good luck
Aug 27, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Detergent dispenser doesnt open
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Jun 20, 2006 | Maytag PDB3600A Built-in Dishwasher
ZANUSSI 695 Integrated Dishwasher
May 26, 2006 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
