Question about Sony DSR 250 - Camcorder
SONY DSR-250 recording, and standby problem.
I can be filming like a football game, or something, and my camera will just like go to stand-by mode. It just stops recording.....
My batteries are charged, and there's a new tape in there...
4 Suggested Answers
  • 473 Answers
SOURCE: Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Posted on Sep 14, 2005
  • 80 Answers
SOURCE: Super8 preservation.
****, I would recommend you go to B&H Photo's web site ( and purchase a film to video transfer box. These boxes are relatively cheap and you don't need the projection screen any longer. Your camcorders lens sticks in one side and your projectors lens in the other and the box takes care of the rest. The quality is much better than projecting the image on a screen. Good luck my friend. Joe Weibel
Posted on Mar 01, 2007
  • 169 Answers
SOURCE: Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Posted on Sep 14, 2007
SOURCE: Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Posted on Jun 30, 2009
0 characters
1 Points
Hi :-) I need at driver for Sony DSR-pdx 10p so we can transfer pictures to pc win7 - where can I find it ? Thanks Anni
The computer should have all the prorgams that makes video camera record media transferable. Usually the computer is has a built in media decoder program least requiring repairs unless any faults were encountered. Requesting camera recorder prorgams are acquriable at computer retails stores. best buy, target, circuit city, radio shack, wal mart, k mart, sears
Feb 09, 2011 | Sony DSR-PDX10P DV Digital Camcorder
Where can i get USB driver for DSR-250
I think the drivers for your camera as my own are no longer supported in Vista or Win 7, but if you grab yourself a Fire-Wire cable you wont need driver okay? Magic I know but it works.
Jun 20, 2010 | Sony Dvcam DSR-250 Camcorder
Can a Sony DSR-200A record to a mini dv
Yes it can record to both dv and mini dv cassettes.
Feb 02, 2010 | Sony DSR-200A Mini DV Digital Camcorder
Where can I find the mic that comes with the sony 250 and how much does it cost just for the mic?
The mic that came with the camera was very poor. Try a Sennheiser K6/ME64 (not ME66).
Nov 20, 2009 | Sony Dvcam DSR-250 Camcorder
Sony MiniDV DSR-PD170 won't playback recorded video
the tape path of the camera needs to be adjusted ,so you need to get that fixed.
Aug 04, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Cannot film
  Dear carooooo, You are dealing with tape not film. Your problem might be in your tape.   Try running your tape on record the full length. Keep your lens cap on. Color balance and use new tape that's for your Sony.         jameskeyboar.
Nov 04, 2007 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Sony have a problem batch of ccd chipsets and with mine i only had a distorted picture in lcd/vf played ms and previous recorded tapes ok.contacted Sony via web site and had it repaired under warranty even though it was 8 months old.
Oct 30, 2007 | Sony Handycam DCR-TRV22E Mini DV Digital...
Camcorder Sony DSR-300 want to burn direct to DVD recorder
You can connect this directly to a DVD recorder. I suggest using S-Video and the two audio channels.
Sep 14, 2005 | Sony Dvcam DSR-300 Camcorder
Video Cameras Logo
22 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
