Bra wire gone inside drum!!!!!!
I dont know how to get a bra wire out of the drum. Its gone in through the holes in the drum, and when I turn the drum I can hear it scraping inside there. How do I get it out?????
  • ANGELA777 Mar 04, 2008
    either a pen, name badge, pencil or something got into the drum. how would i get it out. i cant wash clothes til then, Please Help!!!!
  • 770 Answers
DLB POST!! SEE ANSWER below From old post Solution #1 posted on Jan 26, 2008 bra wire gone inside drum!!!!!! - 0%20stars.png
1ad4dee.jpg Master_Tech
Rabra wire gone inside drum!!!!!! - guru_s.gifg src="http://i.fixya.net/uploads/images/guru_s.gif" alt="guru_s.gif" class="h_mi" /> Guru
Rating: 85%, 47 votes
you will have to open the bottom of the unit there is a pump clean out and a hose to the tub you maybe able to get it from there REMOVING the tub is not an option at this point
Posted on Jan 26, 2008
Bra wire has gone through the holes in the drum and makes a dreadful noise when it rotates, there are now signs of the wire inside the drum. How do I get the wire out
Cannot make out if that is a typo. There are signs of the wire or there are not? If you can see the end of the wire, grip it with a pair of pliers and carefully work it out back through the hole it is stuck in. If there are no signs of the wire, look if you machine has any removable plastic paddles in it. If it has, remove one of the paddles, usually held in by screws and clips, and rotate the drum till you see the wire, and remove it. Also look around the front of the drum behind the door in case the wire is jammed in there. If all this fails there is only one solution and that is to remove the front of the machine and the front of the outer drum to gain access to the gap between the two drums.
Mar 08, 2011 | Neff V4380X0 Front Load Washer / Dryer
When i turn the drum it sounds like something metal is rubbing on it, what can that be
the usual culprit is a rogue bra underwire which has gone through the holes in the drum. feel round inside the drum it be still sticking through a hole if so grab it with a pair pliers and pull it back. failing that if you take the heater out you can recover it through the aperture.
Jul 25, 2010 | Neff W4380X1 Front Load Washer
We have a Zanussi model ZWF1621W washing machine and a piece of bra bone(wire) has gone through the holes in the drum and is stuck and rotating with the drum against the drum outer body how do we get it...
DONT RELEASE SEAL. Tilt machine and remove sump hose get someone to rotate drum in hope you can catch hold of wire. be careful of fingers on drum as they are like cheese grater. good luck this is best way and a little patience will do the job
Feb 12, 2010 | Zanussi ZWF1630 Front Load Washer
Bra wire trapped in drain of washing machine noisy when drum rotates.How can I get it out?
Fishing line was looped through the larger holes in the back of the drum with a lassoo on the end of it & hooked round the wire then drawn out. A very time-consuming procedure in a confined space with a fine bendy light to illuminate the part.
Jun 01, 2009 | Zanussi FJS1225W Front Load Washer
Bra wiore inside drum
HAVE YOU A GOOD BRIGHT TORCH? IF SO I REMOVED MINE WITH A TORCH IN MY TEETH & A SMALL FLAT ENDED SCREWDRIVER, IF YOU CAN SEE IT TURN OFF ALL POWER TO THE MACHINE FIRSTLY THEN USING THE SMALL SCREWDRIVER COAX THE BRA WIRE TOWARDS THE NEAREST HOLE IN YOUR DRUM & THEN FEED IT THROUGH AS BEST AS POSSIBLE & THEN GRAB IT WITH EITHER FINGERS OR PLIERS IF IT IS A STRUGGLE TO PULL IT OUT.
DONT LEAVE IT IN THERE & THEN OPERATE IT AS IT WILL JAM IT & BLOW YOUR EXPENSIVE MOTOR WHICH ARE APPROX £80 OR HIGHER & YOUR PUMP IF IT JAMS IN THE BLADES BEFORE REACHING YOUR FILTER ..
May 22, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bra wire removel
Dont know what model you have. Search the net for a repair manual for your model machine. Some are downloadable. Then remove the tub to get to the bra wire.
Apr 12, 2008 | Washing Machines
PS: have some towels handy to catch the water
Jan 26, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bra wire stuck in AEG washing machine
Hello, to fix this, what you should do firstly, is remove the machine from it's normal position, and then get a handyman to take off the back cover (which is not recommended by the manufacturer) and get right into the guts of the machine. Once you have found and identified the drum, internally, then open the waterproof cover, and note where are the parts and screws go. Keep digging the inside up until you ahave reached the bra wire. Alternatively, if the wire is still visivly poking out of the small holes in the drum, pull the wire out with pliers. Good luck! PS- If this information was helpful, please rate me either solved, thanks for trying, etc. Thankyou! Daniel Ballantyne
Oct 10, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
