Question about Canon I990 InkJet Photo Printer
Ink tank absorber full
How to clean and reset
  • Anonymous Feb 29, 2008
    warning light comes on anda message stating waste ink tank nearly full.
  • 92 Answers
Hi ....
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Do vote if this helps ... Cheers :)
Posted on Aug 07, 2009
SOURCE: waste ink tank full
please help me for repair waste in tank full canon ip3300.
Posted on Jan 24, 2008
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 3 Answers
SOURCE: waste ink absorber is full. How can i fix it?
error code E7 for canon210
Posted on Jun 03, 2008
  • 183 Answers
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
  • Plug in power cable
  • While pressing Resume button press and hold Power button (do nor release the buttons)
  • Release Resume button (still hold Power button)
  • Press Resume button twice in a row (still hold Power button), after that release both Resume and Power button (then the printer standing bye)
  • Press Resume button 4 times then turn off the printer
In this stage your printer has operated as usual.
Regards,
Posted on Dec 02, 2008
THE INK ABSORBER IS ALMOST FULL
This error is shown when the waste ink absorber is full in the printer. Every time the printer runs a head cleaning routine, it flushes some ink through the print heads to keep them clean and clear. That ink runs in to the waste ink absorber. It is normally a large sponge or tank.
The absorber can be can be cleaned, emptied and reset but it is an extremely difficult and messy process. This means that the printer is at the end of it's life. Be careful when moving and disposing of the printer though. The ink absorber is full and so there is a small chance of the printer leaking when it is moved! To be on the safe side, put it in a large bag first.
OR AT RISK OF LEAKING INK TRY THIS PERSONALLY I WOULD NOT DO IT AND JUST BUY A NEW PRINTER
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Aug 16, 2014 | Canon MP250
My canon printer 1p 1000 says the waste ink absorber is full contact service center
hi
you need to replace the absorber waste container. But to ensure you can work around this, do this first. Remove the square rubber at the end of the right side of your printer. Use cotton cloth absorb the waste ink. Clean and wipe the ink around area and place the absorber back into the tray.
Finally clean your print head by using dry cotton swab. If this deosnt work, try this: if it doesnt solve the issue, you must replace absorber waste ink tank .
  • You can manually override it, but I recommend getting it replaced.
    Reset waste ink tank counter CANON PIXMA iP 1000
    Disconnect printer from AC power
    Press and HOLD the POWER button, and connect printer to AC power
    release the the POWER button
    Press the POWER button again
please send me 4 thumbs up
Jul 20, 2011 | Office Equipment & Supplies
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
plese it is problem your printer is not print because some of ink is full printer wast tank clean it and reset press printer resum button two times
if you are not success then you go to in your area service authorised delar
Aug 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Solution: Ink Absorber Replacement Options i550
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Pixma Ip90v waste ink tank full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Dec 16, 2008 | Canon PIXMA iP90v Printer
Printer message is: used ink tank is full. Q. where is it...and how do I empty it?
The waste ink tank on Canon printers is the ink absorber which holds the ink used during Print Head Cleaning process. When the error message indicates that it is nearly full, Canon indicates that the printer should be taken to the nearest Canon service center to replace the absorber. There is no supported "do it yourself" replacement for this piece of the printer. As per Canon:
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
If you feel your product might require service, Canon has excellent service options, and we are eager to provide any assistance you may need. Click the link below to locate an authorized service facility and obtain further instructions.
So, to answer your direct question directly, if the message said "nearly full", you can press OK and continue to print for a short time. If it indicated it is full the printer will not function until Canon services the machine and resets the printer.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 30, 2008 | Canon Office Equipment & Supplies
Waste tank absorber is almost full ~ message
Personally, I wouldn't do it myself, I'd inquire w/ Canon about how much it would cost to have it done first...
Maggie B
Feb 10, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How to fix "Ink Absorber Full"??
The ink absorber is a small piece of material that is used to hold the ink that is scraped from print heads on the ink tanks during cleaning.  I suggest, wearing gloves of course, removing the material, which resembles a sponge, and cleaning it with warm water.  Allow sufficient time to dry, clean the sensor with a cotton swab, and reinstall.  Remember to change the ink tanks at the same time, in order to reset the ink counter.  There are new absorbers available for purchase on the web, if you don't want to clean the old one.  Others have had similar problems, Canon suggests sending the equipment to them for repair.
Oct 19, 2007 | Canon PIXMA iP90 Mobile Printer
Canon I990 InkJet Photo Printer Logo
316 people viewed this question
old marine
old marine
