Question about Kenmore 23822 Top Load Washer
Kenmore 23822 when my washer goes in to the rinse cycle i start to hear a grinding noise and the agitator lifts up and drops and makes a loud thud noise.
  • 2 more comments
  • joepackers Jan 27, 2008
    how do i take the agitator off i took the cap off and seen the inside but i did not see no bolts
    after further inspection i found that it is leaking oil? what should i do now
    yeah its leaking oil buts its just on the motor and not on the floor could there just be a small leak or once it starts to go it has to be repair. we was going to get a new washer in february. you think it would last about three more weeks the way it is.
  • robert samples May 11, 2010
    lean the washer back and check to see if the transmission bolts are tight .remove the cup in the agitator and check to see if the 7/16 bolt is tight see if you can lift up and down on the agitator see if any oil is leaking under the agitator last remove the agitater and see if the inner tub is tight on the tub block
    President:
  • 1,314 Answers
If its leaking oil you have to replace the transmission the transmission has a five year warranty but to take advantage of that you have to have an authorized servicer replace it now the tranny will cost about as much as the labor to put it in around 125.00 but you wont have to do the work if your going to do it i can instruct just let me know if you call a servicer make sure they are authorized to do kenmore warrenty and shop around till you find the best price also you can go to sears website and locate one from there in your area if your going to do it your self you can get the tranny from an appliance parts store cheaper than sears
Posted on Jan 27, 2008
  • robert samples Jan 27, 2008
    well who can say id use it till i couldn't may i recommend a front loader when you get a new one less parts no transmission use 2/3 less water 2/3 less soap and will get your clothes twice as clean
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My washer makes a loud grinding noise when spin cycle is running. If I hold the agitator stationary while spin cycle is running drum will continue to spin and noise stops. I have already replaced the dog...
If dogs and coupling are replaced, then you will need to look at the transmisson, check the piece that holds drum on itself, this bearing can go bad. There is also a seal under the nut that holds on the air bell housing.
There is also a plastic hub that connects the agitator to the motor that can go worn.
Feb 20, 2010 | Kenmore 23822 Top Load Washer
Loud and Grinding during spin cycle
More often than not, something get sucked down into the pump. The pump is located in the lower left of the unit (typically) and can be accessed by removing the front panel. You may need to lift the top section to release the front panel. An example - I recently repaired a washer that had a bobby pin lodged in the fins of the pump and prevented it from spinning so that it couldn't drain. I removed the pin and re-assembled the machine and it has worked perfectly.
Hope this helps! Rate my solution!
Jan 05, 2010 | Kenmore 23822 Top Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Whirlpool washer Mod# TWAS750PQO, Ser# CR3520005
is it possible that the washer was overloaded? if so the agitator has little plastic "gears" that move the agitator one way only, they could have made the sound.
you can also check under the washer to see if anything (like a coat-hanger or something) is interfering with moving parts of the washer
Jun 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Kenmore 23822 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
