Question about EliteGroup 661FX-M Motherboard
Video signal I lost the video signal. Power supply was replaced a year ago. Changed out ram and interchanged them. Every once in a while I can get it show the bios post when switching on and off but then it hangs up. Had a AGP card and removed it and am trying to use integrated VGA port. Any ideas other than replacing MB?
Bwahaha.... gay board
mine is doing some strange stuff. i put in my radeon 9250 when my other machine died, into the same board as mentioned above. soon as windows installs the driver for it, the display goes blank and the pc freezes. any ideas?
Posted on Mar 08, 2008
    Scholar:
  • 58 Answers
If it worked fine before the AGP card was removed then the problem is probably related to your BIOS settings. The BIOS setting that controls the integrated video may be set to OFF.
  1. Insert an AGP video card
  2. connect the monitor to the card
  3. boot to BIOS
  4. check settings
  5. turn ON integrated video
  6. save and exit BIOS
  7. shutdown
  8. Remove AGP card
  9. connect monitor to motherboard video port.
  10. Reboot.
What happened?
Posted on Jan 26, 2008
I bought a SyncMaster 2333 monitor 1 and half year ago. Suddenly, my monitor does not show anything. Turn on/off switch is not working. Sometimes it shows just bluescreen. I am wondering what is wrong and...
This problem usually indicates a failure of the power supply board that runs the video control board. You can fix it but if your unit is only 1.5 years old then its still under warranty, 3 years parts and labor. Go to www.samsung.com and go to the service section to start a warranty claim. It takes about 2 weeks to go out and back to you.
BuddyMc
Feb 27, 2011 | Samsung SyncMaster 2333SW 23" LCD Monitor
Akai lct3285ta will not stay on for more than 30 seconds until it has been turned on more than 20 times. I've tried unplugging it for over a minute. Have owned tv for more than 5 years, and this only...
This problems u have 90% it is the tv Tuner signal board,that the board,where the imcomming broadcasting signal cables plug into it.This problems also 10% could be power supply board have dying capacitors parts.That the board,where the power a/c cord plug into it.Check all over the power supply board for capacitors are bulging ups on tops or puffing up on it tops.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes boards the tv Tuner signal board or the power supply board for the replacement.
Feb 02, 2011 | Akai LCT3285TA 32 in. LCD Television
My HP Pavilion PC will not start. The on button indicates it is on but it is not. Monitor says "no signal". The power supply failed a few years ago and it was replaced. Do you think this is what happened...
I do not know exactly what is going on with your computer, but if the light by the power button comes on and stays on then you can try pulling the ram out of it and then put it back in. A few years ago i had a compaq computer and all of a sudden it would not come on but the light by the power button was on. I thought the computer was shot but i contacted a tech and he told me to pull the ram out and put it back in. I did this and the computer came back to life and worked fine. Good luck. I hope this works for you.
Aug 09, 2010 | HP Pavilion a1610n PC Desktop
Emachine T6410 turns on but the screen says ''No Signal''
This problem is very common when you have a bad ram/ memory module or it is not making sufficient contact. Remove them and clean with a piece of dry cloth and reseated properly. Try it again. If it is still not coming on, the ram may be bad. Get them tested and replaced.
Thanks,
Lolita
Jan 05, 2010 | Computers & Internet
Blue light on power button on, but Monitor shows "no signal"
If you tried replacing your power supply but still cannot put your PC to turn on, you should try checking your memory or your RAM. try reconnecting it, clean the lids of the RAM using an eraser, make sure you erase the lids on one direction and try reconnecting it again.
1. After reconnecting the RAM, try to unplug any hard disks connected to your motherboard, remove external PCI cards or if you have external video card remove it and use the built-in video card.
2. Make sure that the connectors from your power supply going through your motherboard is not loose, dont overtighten as it may possible that you can damage your motherboard from pushing through it.
3. Now turn on your computer, if it works, then your RAM must have been faulty or you have loose connections. Try to plug the hard disks and turn on again your computer, if you tried plugging in every devices and if theres an instance that your computer didnt turn on after you have plugged in that device, then the problem will be on that device that you have just plugged, and that made the computer from not responding.
It really helps alot if you have a spare device because you can test if, the one youre using works well by replacing it with a device that in no doubt that works well.
These are just basics on troubleshooting, and i hope it will helped you troubleshoot your PC or more computers in the future.
Any clarifications or future problems, i would be happy to help you. =)
Jan 02, 2010 | E-Machines T2862 PC Desktop
My power supply failed. Now after replacing it
More than likely the power supply you bought isn't capable of handling the wattage demands of your system. If you do not get ANY indication from your video board (i.e. boot information), chances are the power supply is either too low on wattage output or it's defective.
Aug 21, 2009 | AOpen Computers & Internet
No Signal To my Monitor and no beep.
First refix the RAM and Pci graphic card.
Pull cmos cell from mother bord for 15 minutes then put again into its position then all settings are defaults.
Then if still face problem then check with other RAM.
Aug 13, 2009 | Computers & Internet
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
Monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
Apr 28, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
EliteGroup 661FX-M Motherboard Logo
155 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
