Question about HP PSC 2210 All-In-One InkJet Printer
Dirty glass my hp all-in-one has a dirty glass on the underside. Is there someway I can clean it. Thanks
  • 234 Answers
As per my knowledge, you cannot clean the inner side of the glass untill you are expertised because it is all machine made and it depends on the aligning og the carriage which moves too and fro if the allignment is spolied then you will not be able to print aswell.
It is always recomended to cover the All-In-One.
And if your printer is in warranty you will get it replaced for free.
If not you can get a Out Of Warranty Upgrade from HP.
Call tech support and check the same.
Good Luck
Posted on Aug 31, 2008
I have a lexmark x215. it has a dirty glass on the underside. how do i pull it apart to clean it?
If it is dirty on the underside, you will have to take the scavver unit apart.
Here is the service manual.
http://www.hpitechnologies.com/files/4038.sm.pdf
Nov 11, 2010 | Office Equipment & Supplies
I need to clean the underside of the glass on my Canonscan Lide20
How on earth did the underside of the glass get dirty?
Ok, never mind that... in the end, it's NOT worth it. In the old days, you could have since scanners were as big as printers are today... but now they are definitely NOT designed for the consumer to service. The scanner is designed for accuracy, even if you were to get it all apart, the odds that you maintain the precision and integrity of the bulb, the track on which the bulb moves, etc, are very slim.
Suggestion... How is the printer you have holding up? If it's getting on in age, it may be a wise investment to purchase a dual scanner/printer (as long as you are spending the money).
Hope that helps :)
-- RT
Aug 29, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
I have an HP Office Jet v40. No problems when I
Sannaer glass is dirty: Cleaning the scanner glass and white reference strip Follow the steps below to clean the scanner glass and reference strip: Remove any loose paper debris that may be present.
  1. Carefully clean the white reference strip on the underside of the scanner cover (or top cover) with a clean, lint-free cloth, moistened lightly with isopropyl alcohol. Clean only the white plastic part on the scanner cover.
  2. For those models that have a scanner glass, clean the scanner glass with a lint-free cloth, moistened lightly with glass cleaner. The HP Officejet K series and HP fax 1220 have a scanner opening instead of a scanner glass. Make sure that no debris is in the scanner opening. Use canned air to gently blow dust and debris from the scanner slot.
  3. Replace all removed components and close the unit.
  4. Plug the power cord back in and turn the unit back on.
  5. Make a copy to verify the lines are not present. If lines are still present and there is nothing visible on either the scanner glass or the reference strip, the unit will require service.
Instructions are on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50325&lc=en&dlc=en&cc=us&product=60630&rule=30380&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Cleaning the Glass
OPEN THE SCANNER UNITE SIDE AND CLEAN OFF ALL DIRTS ON THE OTHER SIDE OF THE GLASS,COVER IT BACK AND HERE YOU GO...THE PRINTER SCANSS CLEAN AND CLEAR
Feb 05, 2009 | HP PSC 750 All-In-One InkJet Printer
HP 6110 scanner glass is cloudy
Here is how, but it seems a lot of work.
- Remove all the torx-screws
- Remove the little glass on the left side
- Remove the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
- Remove the Control Panel itself (another two latches&move to the left)
- The whole top of the 6110 is attached to the bottom with 4 latches. I remove that, turn it around and clean the glass.
Note: The cables between 6110-bottom and control panel/feeding unit are long enough to set those things aside.
Dec 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Streaks when scanning and the glass needs cleaned how do I get in to clean the glass on the underside
Here's a link to the instructions for opening the top of the scanner:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
BG
Oct 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP photosmart 2710 dirty glass
hi,
no way.... u cannot clean the underside of the glass... u can clean the glass using a lint free cloth....
thanks and regards
agnel
Dec 30, 2007 | HP Photosmart 2710 All-In-One InkJet...
Scanning glass dirty
hi,
not to worry... u can clean it with a lint free cloth.
thanks and regards
agnel
Dec 28, 2007 | HP Photosmart 2710 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
