RCA dvd home theater system
I hooked it up and the dvds work and the radio works but it wont play the sound off the tv, what do i need to do to fix it
    Scholar:
  • 150 Answers
Check the input to the unit. Try hooking the input to a VCR or another DVD audio output to verify the system is working or is at fault. Sometimes the TV has to have the output turned on or set to Fixed. Most TV's that have an optical output wont output sound over this port unless you are watching a digital program on the antenna input.
Posted on Jan 08, 2010
SOURCE:
Dvd player and cd work but no Radio or tv sound also hooked up a turn table and that wont play. Help
Hi, i think you have to get your unit looked at as it looks like the solder joints are drying up.
Feb 26, 2016 | Sony DAV-HDX266 Theater System
I am trying to hook my home theater system to my flat screen tv to play dvd's and to hear the radio.
The TV has nothing to do with listening to the radio. All the TV REQUIRES in as a minimum is a video input from the RTD. Page 2.
http://www.retrevo.com/support/RCA-RTD217-Home-Theater-Systems-manual/id/2869dj192/t/2/
Your other devices may have guidance in their manuals.
Aug 11, 2011 | RCA RTD217 Theater System
I have rca home theater system rtd215 plays dvds fine but no sound when im watching tv programs i have no cable box just the jacks on my tv [52 projection screen phillips] and i tried hooking them into the...
This reson you are not hearing any "TV AUDIO" through your RCA surround system would be due to your tv sound output not being connected to an audio input into your surround system. You can hear DVDs,CDs and radio possibly mp3 if connected, as these are built in to the amplifier which the speakers connect to.
If the tv has a Line out (via phono plugs) and NOT via headphone out, connect it to an audio input on the RCA surround system. If the RCA has no other available inputs, well....there ain't a lot you can do but watch CSI with the sound from the TV and then Star Wars (for example) through the TV and Surround system.
Best Of Luck
Sep 03, 2010 | RCA RTD215 Theater System
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Newer DVDs won't play properly
you need to buy a cheap av moulator (about 20.00 at most stores) this will solve the problem radio shack has them and so does wall=mart
Jan 13, 2008 | Panasonic Home Theater System System
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
14 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
