Question about Acer AL1711 17" LCD Monitor
Acer AL1711 17" LCD Monitor goes blank without warning
My monitor has repeatedly gone blank and the on/off light goes out. I can get no response from it at all. The first time it happened was when I'd switched on my PC first thing on a morning and typed in the password and after about a minute the monitor went blank. The on/off light button doesn't do anything. I switched everything off and rebooted and it came on and was okay for the rest of the day. That was yesterday. Today it has gone off about 4 times already. I have to turn everything off at the mains and wait about 10 minutes and when I reboot it comes on again.
Mo
    Problem Solver:
  • 18 Answers
The need to reboot your computer to get your monitor working places the blame totally in the computer. You have a virus, or the computer is overheating and shutting down for thermal reasons.
-CharlyV
Posted on Jan 27, 2008
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
Monitor not working it lights up and says acer then it says no signal and goes blank
There are two common reasons for that problem. 1) Your video card on your pc may be having issues. 2) Your monitor is not working properly
Here is a test to isolate the problem to the monitor. Plug it into another pc or laptop VGA or DVI slot and try to power it on again. If it works then you know for sure it's your video card giving trouble. Either gone bad or needs the drivers to be updated/uninstalled and reinstalled.
If it doesn't work then you're looking at some monitor repair or potentially a new one. However since you said you saw the Acer logo, it's a positive sign it's not really your monitor as it would not work all together if it had an issue.
Hope this helps and thanks for using FixYa.com
Apr 24, 2010 | Acer 22" X223w LCD Monitor
My Acer LCD Monitor AL1707A goes blank after 2 seconds
Try this,
When laptop on booting immediately press del.
And the screen will run normally.
But if the screen is still white, force to press power button soon.
And it will shutting down.
After shutting down, repeat this action.
It will work.
Vincent-Jember
Nov 05, 2009 | Acer Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor goes blank
I was thinking about your problem, I just had a similar issue and the problem is that the inverter or the power supply with an embedded inverter had gone bad.
The reason it goes black is because the inverter fails to provide power to the LCD Display.
The only way to fix this is to open up the FPD:
*note these are instructions for the most popular FPD 1730*
1.there should be four screws on the back --> plus two large screws that hold the FPD stand and the Monitor together.
2.Open the back by pulling the cover off
Remove 7 screws holding the frame and the power button for the LCD
3.Remove two screws through holding a silver cover and remove cables.(pinkwhite) (blackwhite)
Please note where they belong before removal**
4.On the edges left and right are two screws 4 total ---> remove and remove LCD off of frame**becareful because the backlight Damaging can cause severe damage to your LCD panel.
5.Choose your model
Your FPD has 3 boards (power, inverter(backlights) Logic Video)
replace the inverter with well known good one
Your FPD has 2 boards(Power with inverter on edges, Logic Video)
replace the power board with a well known good one
6.Then do steps 1-5 in reverse order(putting your FPD back together.
I hope this is significant help
Sep 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor Problem:
You may be encountering a hardware fault that numerous people appear to be having (myself included).
Get a bright torch and point it at the screen once it's 'gone blank'. Look for any text / images that you'd expect to be displayed.
You will normally see a faint display which shows that the problem is just with the backlights. Unfortunately the inverters for these are built into the power supply (Delta Electronics, model no. ADP-40AF) so you will more than likely need to replace this. It's probably easier, simpler and cheaper to buy a replacement (non-Acer) monitor!
Dec 06, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1711 17" LCD Monitor Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
