Question about Maytag Performa PAV3200
  • rampartc Feb 03, 2009
    same problem. legs touching floor and did the self leveling drop. floor may be soft?
  • 114 Answers
There could be a couple of reasons for this. When this occurs, look to see if the load is evenly distributed around the circumference of the tub. If not, redistribute and continue with spin cycle. The machine may not be level. Check to ensure that the machine's leveling legs are making contact with the floor and that there is no movement when you attempt to rock the machine. If the unit is sitting on a soft floor, this could happen from time to time.
Posted on Jan 27, 2008
  • gbonifanti Feb 07, 2011
    I did everthing suggested above. However I still have the issue. It has something to do with snubber part no. ap4045273.
Need to replace the springs how do i remove the top?
Posted on Apr 27, 2009
I have a HotPoint washing machine, and it is leaking water bad. It leaks whenever the spin cycle starts, and the washing machine shakes pretty bad in that cycle. It's my ex girlfriends washing
The leaking could be coming from the exit port on the washing machine. Check the hoses leading from the washer to the drainage port in the wall. As for the shaking, check that the level adjustments at the bottom of the machine are level.
Apr 12, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing machine won't go into a spin cycle.
check the lid safety switch for proper operation
Oct 04, 2009 | Washing Machines
Maytag washer spins cycle
one of the shocks may have broken, usually there is 4 of them, holding the drum to the housing. other thing is to make sure agitator in drum is not loose, to get to scerw remove softener dispenser. this info is for top load machine, as model was not specified
Sep 02, 2009 | Washing Machines
Maytag washer m/n PAV3240AWW
I suggest changing the belt for a new one, in fact if this model has 2 belts, replace them both.
I ran 2 laundromats... this occured frequently due to over loading the machine and then the belt would get damaged just enough to foul up the proper agitation and the spin/drain cycle.
Just change the belts and i'll bet that will get you back into service!
Let me know.
May 26, 2009 | Maytag Washing Machines
Shakes on spin cycle
yes bad struts can cause this problem also if you have it on carpet you would be better off cutting a piece of plywood for it to sit on as it will shake when sitting on carpet most of the time
May 19, 2009 | Maytag Neptune MAH7500A Front Load Washer
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Washing Machines Logo
401 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
