Work yesterday, but not today. It's only a year old? I notice a clicking as the monitor cycles, green light - red light - green - red keeps flashing, then turns itself off. I tried (rebooting) the set but no go. The screen is black.
I diagnosed the same problem on my FWD-42pv1 as a problem on the Y-SUS board. The fuse on that board was blown, and the board itself was bad (replacing the fuse was not enough to fix it). The symptoms were exactly the same - the LED cycling red/green, and then finally stuck at red.
With a new Y-SUS board, the TV has been working fine for a couple months.
in pwoer up i can not see signal after cheking the t.v i thenk the problom is in the card name av...
(More)
in pwoer up i can not see signal after cheking the t.v i thenk the problom is in the card name av main bord
my sony plasma tv is showing pictures in black and white. l would like to adjust it so that it will...
(More)
my sony plasma tv is showing pictures in black and white. l would like to adjust it so that it will show color pictures
is this model good as a regular tv? i bought it on e-bay but myhusband says its best as a monitor...
(More)
is this model good as a regular tv? i bought it on e-bay but myhusband says its best as a monitor not tv.please help
Wii would not work plugged into the tv so I had to plug into the DVD/VHS. I can get Wii now but the...
(More)
Wii would not work plugged into the tv so I had to plug into the DVD/VHS. I can get Wii now but the picture is crappy. How can I fix this?
I'm not sure if I'm doing this right...I have a sony FWD-42PV1 Flat Panel TV. Can I or is it...
(More)
I'm not sure if I'm doing this right...I have a sony FWD-42PV1 Flat Panel TV. Can I or is it possible to hook up my Direct TV box to watch regular HDTV Channels or is this Flat Panel only good when hooked up to a computer. Thanks
