FixYa.com
Tags:
Umax Astra 2000U Flatbed Scanner
Scanner screen (by 3 users)
posted by davidshort on Jan 26, 2008
My scanner developed a thin green line down the left and a broader yellow line down the right; they both increased in width until I was left with a space only large enough to scan a postcard. I would let it rest after about three scans and could get the narrower bands back. Today I went to use it again, but this time the entire screen was dark green and, unlike the earlier banding, not even translucent. The lamp is on, no less bright than as new, and it moves as it should.
Comment by davidshort, posted on Jan 30, 2008
Can't evaluate the suggestion yet; I ned a free Saturday to tackle the problem and see if the solution works.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by uchanduch, posted on Feb 25, 2008
I have the same problem... and i already clean everything, but nothing change ... i'm using Windows XP pro, any other solution Thanks :)
Comment by Guest, posted on Feb 25, 2008
Yes, I have the same problems, and I already clean everything, than can be cleaned inside the scanner housing... but nothing change ...
I use Windows XP pro... can anyone have better solution?please..... :) thanks
Solution #1
posted on Jan 28, 2008
Not Rated (0)
nitinbabbar
Rank:Wiz Wiz
Rating: 81%, 50 votes
open the top glass cover,after that u can see the lamp assy ,on the banx
ck side of that assy there are some mirrors,clean all that mirrors with a cotton bud ,fix it again n chech\
do revert
th
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Scanners problems?
Scanners
scanjet 4050
can not install software from... Answer This...
Scanners
driver for umax scanner 4500
i can't find driver for umax... Answer This...
Scanners
help
do you have scanner codes Answer This...
Umax Astra 2000U Scanner
I have a UMAZ Astra 2000U... Answer This...
umax astra 2000u scanner's...
Hi sir please tell me: I have... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
