Nintendo Wii Console Logo
Posted on Dec 25, 2009
I cannot select the language. I have pushed every
I cannot select the language. I have pushed every button and even restarted the Wii several times.
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Jan 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
1714
Points
21
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
kibriya16
2helpful
1helpful
Wii freezes at Configurable usb loader
# Run apps/ATDM/boot.dol from the Homebrew Channel
# Select IOS250 as the IOS to start and push A to confirm.
# Navigate to "System Titles" and push A to confirm
# Select "IOS222" and push A to delete then A again to confirm.
# Select "IOS223" and push A to delete then A again to confirm.
# Select "IOS249" and push A to delete then A again to confirm.
# Select "IOS250" and push A to delete then A again to confirm.
# Push Home to exit AnyTitle Deleter Mod
# Now run the IOS249 app and choose to install IOS250
# After the installation is done it should exit automatically.
# After it exits, restart the Wii then run the cIOS 222 Installer app.
# This time choose IOS250 to perform the install with!
# Select to Install Custom IOS 222 and choose the first (default) option
# Wait for download and installation to complete
# Start HomeBrew Channel and start the cIOS 222 Installer again
# Select IOS250 to perform the install with again!
# This time select Custom IOS 223 and select IOS38 merged with IOS37
# After the installation your games should work perfectly fine..
My wii is in german.and l want to put english on it
  1. Access the Wii System Settings.
  2. Click on the blue arrow twice to reach the Wii System Settings 3 menu options.
  3. Select "Language" and press the A Button.
  4. Highlight the language you wish to change to (English, French, or Spanish) and press the A Button to select it.
  5. Move the cursor over "Confirm" and press the A Button.
I want to install language arabic to my pc now from the web
  1. Download fbarab.zip from http://zsigri.tripod.com/fontboard/fbarab.zip
  2. Extract the installation package from fbarab.zip with adecompression utility.
  3. Run fbarab.exe to install the Arabic keyboard layouts.
  4. Restart Windows.
  5. Load the keyboard layouts:
    1. Click on the Start button.
    2. Click on Control Panel.
      • The Control Panel is directly accessible in the standard Startmenu but it is inside Settings in the classic Start menu.
    3. Click on "Date, Time, Language and RegionalOptions."
    4. Select the "Add other languages" task.
      • Or click on "Regional and Language Options" and select the Languages tab.
    5. Check the "Install files for complex script and right-to-leftlanguages" option and click on the Apply button.
    6. Click Yes when you are asked to restart Windows.
    7. Go to "Add other languages" again and click on theDetails button.
    8. Click on the Add button.
    9. Select Arabic in the drop-down list of input languages and selectArabic ASDF Eastern or Arabic ASDF Western in the drop-down list ofkeyboard layouts.
    10. Click OK as many times as you are prompted to and then close"Date, Time, Language and Regional Options."
1helpful
My console keep on blinking i cant seem to operate on the screen
you have to sync the remotes to the wii box[consol]
On the wii box there is a door under the power/restart buttons, in there is a red button push it..
next on the remotes open the battery cover, look for the red sync button,
push the sync on the wii box first then on both remotes to sync [synchronise] them.
it can be a pain in the... but keep trying untill it sync's
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
  4. Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Wiimote unresponsive to anything
Have you tried restarting the Wii and then synching the wii remote to the wii ?
Just below the disk loader is a hinge you can open to insert a sd card, There is a red button - Push it
Take the battery cover of the wii remote, their is a red button - push it
Push both buttons close together time wise
1helpful
Stuck on forgien languages.
push menu button once
push > button 4 times
push > button 3 times
push menu button once (now you are in the language selection screen)
push > button untill english is chosen
push menu button
now push far left button (has a monitor pic on it
Now you are back in english enjoy
bcmalloy
1helpful
Setting up w/TV
Sync your remote with the wii. Open the small white door on the front of th wii and push the red button. Then open the back of the wii remote and push the red button there. The remote should sync and you should be fine.
Adjust the date on the i70
Hey Mat,
You can find your product manual here:
http://www.samsungcamera.com/popup/download.asp?prol_uid=4148&prj_uid=733
You'll find once you download the manual's pdf, it'll be on page 20 of the pdf manual. The sample is below, but it's much clearer on the pdf manual. Best of Luck!
When Using the Camera for the First Time : Setting up the Date / Time and Language
When the camera is turned on for the first time, a menu will be displayed
in the LCD monitor to set date, time and language. This menu will not be
displayed again after setting up the date, time and language. Set up the
date, time and language before using this camera.
■ Setting up the language
1. Press the [Language] menu button.
2. Select a desired language by pressing the
vertical smart button.
■ Setting up the date, time and date type
1. Press the [Date & Time] menu button.
2. Select a desired date type by pressing the
3. To change the date, select the [2008/01/01]
menu and press the vertical smart button.
4. To select Year / Month / Day and Hour :
Minute, press the horizontal smart button.
To change the numbers, press the vertical
smart button.London
● You can select any one of 22 languages. These are listed below :
- English, Korean, French, German, Spanish, Italian, S.Chinese,
T.Chinese, Japanese, Russian, Portuguese, Dutch, Danish,
Swedish, Finnish, Thai, Bahasa (Malay / Indonesian), Arabic,
Polish, Hungarian, Czech and Turkish.
● Even if the camera is restarted, the language setting will be
maintained.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
