Question about Magellan MAESTRO 3100 98083401 GPS Device
Maestro 3100won't power up
I left mine plugged into my truck with the power off for the last month. Now when I try to turn it on it will not come on. Have I burnt up the battery? Where can I take it in for repair?
    New Friend:
  • 24 Answers
I understand the problem in the unit so to turn on the unit the so please follow the below steps.
-> At the left hand site you can see a small pin hole named as (reset) just inseret a paper clip into the hole and gently push it in side then
-> Press and hold the power button for 20 seconds .
-> The unit will turn on
If still the unit is not turning on means please call to this number :
Technical Support :
North America: Telephone - 800 707 9971
Posted on Jan 27, 2008
2 Suggested Answers
sids8065
  • 61 Answers
SOURCE: Will not come on.
GPS units should never be permanently left in vehicles. The vehicle interiors get way too cold or hot depending on the climate you live in and is very damaging.
Try taking it indoors and connect it via the supplied a/c wall charger and see if it turns on.
Posted on Feb 28, 2008
Will not come on. Has power from the outlet.
mine did the same thing finally i tryed unpluging it from back of tv well still plugged in and then pushing in the power button on the tv and mine turns on but i cant use a remote to shut it on or off and cant seen to find any info on this tv anywhere so for last 3 months that is how ive been turning it on and off any ideas ??
May 19, 2010 | Proscan 32LA25Q 32 in. LCD TV
Tip
How To Reset Your Magellan Maestro/Roadmate GPS Units
Factory Reset
Do not attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
  1. Locate the button marked "Reset" on the left, right or bottom of the unit.
  2. Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
  3. If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
If your Maestro GPS Touch Screen Doesn't work, try performing a Hardware Reset
  1. Remove the Magellan Maestro from the holding cradle.
  2. Hold down the "Power" button on the right side of the device, until the unit powers on.
  3. Straighten the end of a paper clip. Place the paper clip in the reset hole, located on the left side of the GPS unit. Hold down the "Reset" button for 10 seconds. Remove the paper clip.
  4. Turn the Magellan Maestro unit off by holding down the "Power" button. Turn the unit back on again. The device is now reset.
If your Roadmate GPS is locked up, try performing a Hardware Reset
  1. On the RoadMate, press + + - - + -
  2. The "hidden menu" will appear.
  3. From there, you can access the shell and perform a hard reset.
on Feb 15, 2011 | GPS
Maestro won't power on even after charging and reset
if your sure its charging, plug it in and press and hold the power button for up to ten seconds, if that fails, let me know.
bill
Oct 31, 2009 | Magellan Maestro 4000 GPS
I only used this device once after ordering it from Dell last month. Now it seems to have malfunction since it only says your device needs to be restarted and after it restarts it goes on the say the same...
plug it into your usb cable to your computer for a few hours.
then start the gps then press/slide power switch for ten seconds to reset the unit.
if that fails, start the gps, locate the reset button (little tiny hole) either on the left,right or bottom of the gps. gently depress reset using a paper clip or something similar
let me know if you need further help.
bill
Oct 29, 2009 | Magellan Maestro 4700 Car GPS Receiver
I have a magellan maestro 5310 which I have had about 4
press and hold the power button for up to 10 seconds. that should reset it. after you do that, go HERE and download and install the latest update for your 5310
bill
Aug 26, 2009 | Magellan Maestro 5310 Car GPS Receiver
Gps will not turn on
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
you can email me through here or email to.... wmetz@comcast.net
Jul 18, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Brand new Magellan Maestro 4000 does not turn on or indicate powe
I had the same problem and I solved it by cutting a few strands of speaker wire and twisting them together and inserting them into the center of the generic car gharger end which plugs into the Maestro 4000, It seems that the 4000 has a very small center conducter on the GPS itself and by adding a few strands of speaker wire about 1/2" long into the plug before pluging it into the 4000 it allows it to makes contact with the small power inlet conductor which is smaller than most generic cigarette lighter 5vdc power cords. I did this to mine and it powered up right away. The other solution is to buy the actual car power cord from Magellan which has the proper size connecton and makes proper connection all the time.
Dec 24, 2008 | Magellan Maestro 4000 Handheld GPS...
Magellan maestro 4040
plug the unit in and press the silver button by the left side and make sure the unit is fully charged if not,plug in the home charger and iti will be fully charged 3 to 4 hrs,also if the battery is fully charged the unit should turn on after you press the silver button on the left side and hold for a few secs. without the car or home charger.also chk your cd manual for further info.let me know what happens.ok.
Feb 27, 2008 | Magellan Maestro 4040 GPS Receiver
Will not come on.
Jan 24, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan MAESTRO 3100 98083401 GPS Device Logo
49 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
