Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Black spots and marks on laundry
I had a Maytag Neptune front loading washing machine that left black smudges and spots on my laundry.  Sears Repair fixed it many times, each time a different diagnosis, until it was finally completely re-built--new motor, new drum, etc.  It still left black marks.  In frustration, I threw it out and bought a Bosch Nexxt 500 series front loader and am now experiencing the exact same problems.  I don't use alot of detergent.  I rarely use the hot setting, most of my washes are cold, with an occasional warm.  I stuff the washer to capacity, based on the instructions from the Maytag Neptune video.  What the heck is this?  I'm ruining my laundry.  HELP!
  • 1 more comment
  • cmtes Jan 26, 2008
    Thanks for your thoughts, but we don't have any steel buttoned shirts and when I wash jeans, I do them with other darks and ALL my clothes, sheets, towels have marks on them.
    I had Sears repair to my home on 10 occasions. I hate to say it, but everyone had a different diagnosis and no one was correct. I had similar experience with my GE built in refrigerator with Sears Repair and finally had a GE repair person diagnose correctly. I don't think Sears employs alot of competent personnel, unfortunatley. Your suggestion to call the manufacturer is a good one, but I have had the problem now with two different hight end front loaders. But I will try it. Thanks!
    I don't wash any greasy clothing, just so you know--do you know how I can clean the hose? Is this the 1st reason that you think is really the problem?
    Also, I will definitely try a few hot washes with a descaling agent--are you talking about Calgon bubble bath? (I wouldn't think so but who knows?) Where can I get a descaling agent? Also, when I do this, should I have clothing in the washer or should I do it on empty?
    Thanks so much for your help! I really appreciate it.
  • 871 Answers
Didnt you wonder that it might be your clothes? are you putting steel buttoned shirts? or jeans, this usually gives rise to smears and a lot of stuff other than outrageous scratching.
beleive me man. this usually happens.
Posted on Jan 26, 2008
    Sergeant:
    Champion:
  • 317 Answers
This is really weird!!!! Check with sears and see if this model is on the defective or recalled list. If not, call the manufacturer and have them send someone out, and show them what is happening.
    Genius:
  • 1,067 Answers
Maby sumthing in the line on the hose dirty tar sumthing weird comming in or are u waching alot greesy clothes
  • 3 more comments
  • nick helpap
    nick helpap Jan 26, 2008
    your problem may be because you generally use a 'cool' wash ie 30' or 40' Try a really HOT programme or two to see if this will remove the deposits that have built up What happens is that quite a lot of 'undisolved powder' tends to congregate inside the machine because of 'low temperature washes' Its a good idea now & then to use CALGON or some other descaling agent.
  • nick helpap
    do that 1st ok
  • nick helpap
    do what i said 1st ok this proably the real reason
  • nick helpap
    ya do hot washes that should help u mark this as fix ya if it worked ok
  • nick helpap
    wash clothes in any store sell it that sell washers
Maytag mah9700aww,will not spin(laundry soaking wet)
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
,.,./l;
Mar 05, 2011 | Maytag Neptune MAH9700 Front Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
I heard my Maytag Neptune shake hard today when a load of laundry was going. I assumed the spin cyle got got offline for a second. The washer seemed fine. Then I did another load of laundry. While it...
do NOT call the Blue guys from Sears,,,he told me it would cost more than $2000 to fix a machine that will wash but not spin or drain ( I could get it to do both by pushing certain buttons). It is now outside and I have a used $215 washer that is doing great.
Nov 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Leaving brown/black smudges
This is most likely caused by laundry getting stuck in the front seal of the washer.
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
I am doing a load of laundry the washing machine maytag neptune
This means locked rotor. you have a bad motor control unit. take the door off by removing the 4 screws also take the side/front panel off. You will see the motor control board. Do you have a delay wash cycle? If you do set it to delay wash remove the jp4 connector if the unit tumbles on it's own then the motor controller is fine but if it does not then you have a bad motor control board. Check it out and let me know. also there is a fuse on that board if you can locate it and check for continuity that will also help diagnose it. MAKE SURE YOU UNPLUG IT FIRST THOUGH!!!!
Jun 04, 2009 | Maytag Neptune MAH6500A Front Load Washer
Black mold on rubber seal
youust replace it, and start from scratch. From day one you have to maintain the boot with Affresh, whipe out water
Nov 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Black streaks, smudges and dots from drum
take a rag and wipe around front door boot first does any thing come off on rag if this ckd ok does it keep a roaring noise when spinning? if so suspect rear bearing or corrision on spider this is tub support behind basket..ask for estimate before repair as this could result in major expense to repair good luck
May 28, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Black marks
sounds like a bad rear bearing.causing grease to get into laundry.
May 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Black spots on laundry
Mr CALGON please note my plug but it is good
Oct 13, 2007 | Frigidaire GLTF1670A Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
559 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
