Samsung Tocco Ultra Cell Phone Logo
Posted on Dec 25, 2009
Taco Lite phone lock
I set my taco Lite up to require a pin upon start up. I forgot this pin however, and now I'm unable to access my phone. Is there any way I can reset or remove this pin?
I have revieved my PUK code, but I am not able to get to somewhere that I can enter it no matter how many incorrect codes I enter. How can I remove the code that I set?
I have tried ringing orange, they suggested removing the SIM card, this didn't do anything, even with a different SIM card in it still asks for the code. I have also tried ringing samsung, but they are not open today. What can I do?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
865
Points
Forgot my password for my phone lock what do i do ?
3answers
First My sister inlaw has a 3/4 recirc line. used the by pass h&c under last faucet to use cold as recircu line. Note acutal 3/4recirc is in kitchen but even thou closer to water htr. it is last for...
I don't understand everything being asked, so add a comment any time.
Problem1 is excessive electric bill.
Suspect is new 120Volt Taco recirculation pump.
Look at motor nameplate for amps and watts and HP. Taco pump is usually robust 1/3 HP which is 252 watts or same as running four 60 watt light bulbs.
If pump runs 18 hours per day x 252 watts = 4536 watts or 4.5 Kilowatts per day
Buy a kill-o-watt meter that plugs into outlet, and plug Taco pump into the meter for 48 hours.
This will give you total watts used for that time period.
1000 watts = 1 kilowatt.
Electric bill is probably 12 to 20 cents per kilowatt.
So if Taco uses 4.5 kilowatts per day, that is $.54 to $.90 per day multiplied by 30 days.
So cost is $15 to $30 per month.
Problem2 is Taco runs too long.
Taco operates either by thermostat or by timer. You choose which mode by using slide switch that is usually located under the timer dial. Set switch to TIMER to use timer, and ON to use thermostat, and off to turn TACO off.
If Taco is set for thermostatic operation, the Taco might be defective. Or there could be crossover problem at single handled faucet.
Another problem could be air in the water line: install air vent.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/How-to-set-timers.html
Have a taco 24 hr timer on water heater of home we purchased. pls descvribe how to set it to circulate the water just twice a day for a couple of hrs. thx, mg
Your question is very big because recirculation systems have a lot of parts and options.
Please open following link for re-circulation system resources that show pictures of how the system works. After reading information, add a comment with more questions.
The page shows two different types of Taco timers. One timer is programmable and the other timer is called analog timer where the timer dial rotates just like a clock. Small pins located on dial face are set inward or outward. As the dial rotates, the pins move a tiny on-off lever that turns the pump on-off. The pump can also be set to operate thermostatically. You choose either timed operation or thermostatic operation using slide-switch located under timer dial.
Look at, and read information on link above. Try some things on your timer so you are familiar. And then add a comment with specific description of your Taco timer, and include what you have done so far.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
My Taco 006 circulation pump quit working. It make a vibrating noise and does not pump. I just bought it a year ago. Can you help.?
Usually when these motors slow down, they get hot and burn out.
You can try taking it off and cleaning with CLR, but normally when they stop working, they do not revive.
I am not sure what the warranty policy is from Taco, or if Taco has a parts list.
I think following link takes you to the Taco website:
You can contact them for warranty/parts information
http://www.taco-hvac.com/en/products/Hot-Link%AE%20Domestic%20Hot%20Water%20Recirculation%20System/products.html?current_category=398
Link below has information on recirculation systems with links to manuals and competitive products
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
Diagram for a Taco 572
We were able to find some instruction sheets, including wiring diagrams for the Taco 555-573 series zone valves on the Taco website: http://www.taco-hvac.com/uploads/FileLibrary/100-3.2a.pdf
Hope this helps,
ComfortGurus.com
www.comfortgurus.com
866-519-2461
I bought a new house and the water heater has a circulating pump with a Taco 265 timer. No instruction manual so I can't figure out how to set the timer. You wouldn't happen to have a little instruction...
Maim website:
Main website Search for Taco 265-1 gives link to manuals:
http://www.taco-hvac.com/search.html?gsearch=Taco-265-1&action=results&cb_products=YES&cb_filelibrary=YES&cb_news=YES&search_type=all_terms
Direct link to pdf manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.taco-hvac.com/uploads/FileLibrary/102-067.pdf
Instructions show series of actions to set digital program
Press h key ...
Press m key...
Press Day key...
Press Prog. key to enter...
1helpful
I have a Taco circulating pump #003-BCY-3 PNP. I don't know how to set the analog timer?
Adjust dial to the correct time. Pivot the white pins out to have the pump work during that time. In other words not just one pin, but all the pins from say 6am to 8am. Was a bit confused the first time I saw this set up as well. Good luck
2answers
Forgot privacy password for samsung taco lite
i have a password for my messages on my phone so no1 can look at them but i have forgotten the password. any cheat or ANYTHING any advice for me on what to do?
1helpful
Taco timers and Surge Protectors
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Sep 06, 2009 • Plumbing
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
