FixYa.com
Tags:
Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 driver download (by 2 users)
posted by dragmcs06 on Jan 26, 2008
I have downloaded the driver from the Lexmark website and saved it to My Documents. I have XP. When I try to open the file, it gives me an error message and says it's "not a valid Win32 application."
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by donkeys, posted on May 06, 2008
it has error 0502 on my Lexmark 5150. What does this code mean?
Solution #1
posted on Jun 20, 2008
Not Rated (0)
melvigom
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
please try these steps
  1. Reboot the PC.
  2. Make sure the printer is selected as the default printer in the Printers folder and try to print again.
  3. If printing fails, you will need to download the printer driver again. To do this:
  4. Create a folder on your desktop and call it Lexmark.
  5. Go to our Drivers & Downloads center. Note: The name of this page/site may be slightly different in your region/country.
  6. Click Printer Driver.
  7. Select the Related Product Name from the drop-down menu.
  8. Select your Operating System from the drop-down menu.
  9. Select the desired Language from the drop-down menu.
  10. Select the latest Driver File and click on the File Name to detach it to the Lexmark folder on your desktop. Wait for the download to complete.
    Important: Make sure any copies of the driver from earlier installations are uninstalled before you install the downloaded version.
  11. Install the downloaded driver as follows:
  12. Open the Lexmark folder and double-click on the downloaded file.
  13. When the WinZip Self-Extractor screen appears, click on When done unzipping file open: <the printer file name>. (The printer file name will appear beneath this option.)
  14. Click Unzip. The installation program should autorun. Follow the on-screen prompts to install the printer.
  15. If the installation program does not autorun, locate the newly created LXK___ folder for Setup.exe and double-click on it. An installation program will run. Follow the on-screen prompts.
  16. If you are prompted to install the printer for all users, click Yes.
  17. When the installation is complete, restart the PC.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
dirty glass inside scanner
have you found a way to clean... Answer This...
cleaning the inside of Lexmark...
have you found a solution to... Answer This...
X5150 and Vista print issue
Purchased laptop with Vista... Answer This...
Fax Problems
Problem setting up fax, no... Answer This...
lexmark 5150 printer
printer pulls paper *******... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
