Question about Kenmore 22422 Top Load Washer
70 series wont fill w/water
My 70 series will not fill up w/water
  • Den-Den2 Apr 07, 2008
    My Series 70 will fill with water on the initial start up of each wash, with good water pressure. However, once it has gone through the first cycle and begins to refil for the rinse cycle, it comes out at a very low trinkle (no noticable water pressure at all.
    After the machine had not filled to the proper level after an hour, I manually poured in water to the level required for the machine to kick into the rinse cycle and then the machine completed the remainder of the cycles fine.
    Today was the first that I had noticed this happening and it happened twice for me.
    What is your suggestion for fixing this problem?
  • robert samples May 11, 2010
    does it have any water coming in at all did it just start doing this all at once or has it been getting slower and slower
    Problem Solver:
  • 19 Answers
CHECK SCREENS IN WATER VALVES FIRST. CHANGE TEMPERATURE SELECTOR TO COLD ONLY, SEE IF IT WILL FILL. IF IT DOES FILL AND SCREENS ARE CLEAN YOU MOST LIKELY NEED A WATER SELONOID.
FXIT
Posted on Jan 30, 2008
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
Kenmore series 70, water wont shut off while filling
Will it shut off if you unplug it? If not then a bad solenoid on water valve then need to change water valve. If it does then, need to check pressure switch, timer and wiring harness.
Dec 01, 2010 | Washing Machines
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
My kenmore 70 series wont stop filling with cold water. the hot water stops filling.
you need to replace the water inlet valve on back of washer as the cold water side is not opening,it's easy,remove the 2 top head screws,flip the head up,use a screw driver to pop the 2 clips out(1 on each side top),unplug the wire jack,now pull the back,back so you can get to the valve-mike
Mar 21, 2009 | Kenmore Washing Machines
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Series 70 Washer Won't stop filling
yes and also make sure fill tube is not clogged or debreed
Jul 05, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
213 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
