Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Won't brew. The clock works. I hear a "click" when I push the brew button, but it will not start brewing. It's slightly over a year old so no warranty.
  • 2 more comments
  • SpoiledRottn Jan 27, 2008
    I will certainly check that out. Thank to you for taking the time to respond. I'll report whether or not that fixed my problem.
  • roadtreasure Mar 14, 2008
    I have the same problem. I have checked the fuses (2 in series) and they are fine. Any other suggestions?
  • Anonymous Apr 08, 2009
    I hear the click when button is pushed but no water runs thru
  • Anonymous Mar 18, 2014
    Lights up when plugged in but none of the buttons operate. The "delay brew" and "brew now" lights light up when plugged in as well as the round clock display and the brew strength button "regular". Pushing any of the buttons does not change/operate anything.
    Genius:
  • 1,554 Answers
It is highly likely the thermal fuse to the hotplate is blown.
you will have to open the unit and look for a small silver bullet shaped with a wire on each end, one end is pointed and has what looks like colored plastic.
you will have to have ohmmeter to read continuity through it . it will show as a shorted when working and open when it is dead.
these are easy to find but the correct temp rating needs to be the same or it may not blow when needed to prevent a counter fire.
The fuse is clamped to the wiring with brass because solder will degrade over heat and time.
Posted on Jan 26, 2008
My black and decker coffee pot wont brew everything seems to be fine all the lights and the clock work but when i push on it wont start brewing
There is a momentary contact switch that is probably. You gran get one at the mfr. or maybe locally. When you press the brew button, you should hearing it engage . That would be a sound and a click like something has connected. If there is no sound, then your momentary contact switch is bad. Not too expensive. Probably a 5-10 minute job.
Feb 02, 2013 | Applica Black And Decker 12 Cup...
I'm unable to push the brew unit all the way in. This started when the brew unit was not properly inserted when the machine was turned on causing it to jam. I found the instructions that said remove a...
Hi
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won't go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Apr 14, 2011 | Gaggia Syncrony Logic 74884 Espresso...
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
I took the brewing out of the machine and tried to cleanit. By accident it clicked as it brewed coffee. Now I need to click it back so I can put back the brewing component to the machine. How can I...
This is for a Vienna but they are close and it should work.
Remove the dredge drawer. Open the door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Squeeze until it clicks like you are going to remove the unit and pull carefully, but firmly with a quick pull. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please call your service center.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group. Done
Nov 24, 2010 | Saeco Incanto Classic Espresso Machine
I have Mr Coffee APX33; I do not know how to set the coffeemaker to turn on automatically. I do not have the manual. Hope you can help. Thanks! Larry
First you have to make sure to set the clock for the correct current time:
Press down and hold the SET button. Then alternately press the UP and DOWN buttons (indicated by arrows), until you reach the current time, then release the SET button. (there is a PM indicator on screen but not an AM indicator - if you don't see the PM you are at AM)
To set the time for the brew to start in the future:
Press and release the MODE button once and the Delay Brew Clock picture will start flashing on the screen.
While the Clock picture is flashing - hold down the SET button while you use the UP and DOWN arrow buttons to set the desired brew time (you can hold down an arrow button to get there faster). Release the SET button and now that brew time is programmed. (After a few seconds the clock picture will disappear but the future brew time is programmed.)
To activate the delayed brew:
Press and release the MODE button once. The Clock picture will be flashing and the time shown will be the time that you previously set for the future brew). While the Clock picture is flashing - press and release the BREW button. The Clock picture will remain on steady. The BREW light will not come on until the time in the future that you have programmed.
Pretty confusing - but it does work. Just remember that if you see the Clock picture on steady - the machine will come on at the time you have set in.
If you want to use the machine earlier - while the Clock picture is steady - you just press the BREW button and it will brew.
If the Clock picture is steady but you want to cancel the automatic future brew - just press the BREW button twice. (This turns it on and then off and cancels the future brew).
I can send a copy of the manual if you like. Lennyg678@aol
Sep 17, 2010 | Mr. Coffee APX33 Coffee Maker
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Hello- I have a Saeco Italia machine, about 4
Try this press the pre ground button then the coffee brew button, if water flows from the spout then the grinder chute is blocked, if no water flows then the brew unit is screen blocked.
If grinder, then remove the brew unit and check the chute from the grinder.
Sep 27, 2009 | Coffee Makers & Espresso Machines
Brew Unit Stuck Seems to be in Mid Cycle
Remove the dredge drawer. Open the right side door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please give us a call.
To return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
May 02, 2009 | Saeco Incanto Classic Espresso Machine
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
650 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
