Question about Audiovox AMP522A Car Audio Amplifier
Wiring diagram hello need a wiring diagram for rampage amp-522a and high input plug can you help
  • Anonymous Jul 16, 2008
    need a wireing diagram
I don't have an answer to this problem and I agree with the "WIZ" this amp is not very great. I would however like to fix mine.
could you do me a favor and unscrew the plate on the bottom of the amp (four screws) and look at the colored bands on R 10 so i can replace that resistor? All you have to do is e-mail them to me. It would really help me out.
Thank you.
Posted on Sep 14, 2008
    Sergeant:
  • 203 Answers
Most amps wiring is universal. If u need a high imput plug you might be out of luck they usually come in the box that the amp came in. The input colors should be White and white / blk for left side speakers and gray and gray / blk for right side. I also recommend dumping that amp right in the trash can , sorry to say it like that but that amp is a piece of junk you probably wont get much life out of it, they dont put out anything. Anyway, good luck if u end up using it.
Posted on Jan 28, 2008
Noise after amp installed
Check its wiring. There is many things to consider when wire it with; otherwise audio will be distorted at high level volume. It should be done according to wiring diagram. Wiring diagram to many sets are illustrated by the site give below. Check it.
Jul 05, 2014 | Crunch Car Audio & Video
Spark plug diagram for 1982 dodge rampage
According with the 1982 DODGE TRUCK RAMPAGE 2.2L 2BL 4CYL REPAIR GUIDE...
Fig. 3 Engine 2.2L - Firing order: 1-3-4-2 - Distributor rotation: clockwise
Hope this helps, and I'll appreciate your time and consideration if you leave some testimonial comment. Have a nice weekend and thanks for using FixYa.
Jose.
Oct 15, 2011 | Cars & Trucks
I want to hook up a slim sub for my truck using this amp. how can I do that? Because this amp plays everything not just the bass
You will need to connect the low level input leads from the head unit to the amplifier (they are RCA cables). If there are no low level leads from the head unit, you will need to connect the wires from the speakers directly into the high level inputs using a wiring harness which should have been included with the amp. It should include a wiring diagram. You will need to use that diagram in conjunction with the truck's wiring diagram in order to know which wires to connect. They are color coded and once you have the vehicle wiring diagram (which can be downloaded by searching for it on google.com), it should be easy to determine which wires to connect.
Mar 04, 2011 | Audiovox AMP610 Car Audio Amplifier
What wires do I hook up to the high level in plug that came with my dual xp2100 2 channel amp
First, know that you need either high level input or low level input, but not both. Low level input is preferred (RCA cables). If you must use high level input because your head unit doesn't have RCA jacks, you connect the speaker outputs from the head unit to the high level input of your amp. The high level input plug probably has a black wire, this is "signal reference ground". A pair of grey wires which are right positive (grey) and right negative (grey with black stripe). And a pair of white wires, left positive (white) and left negative (white with black stripe).
Feb 26, 2011 | Dual Car Audio & Video
Jensen XA 2100 Amp. Need High Level input plug diagram. In other words need to know what each of the 6 pins connects to.
the black wire is ground, white is + and white/black is - that's for the left side speakers and the gray is + and gray/black is - that's for the right side speakers and that hooks up to the speaker wires coming from radio to high level input plug if you need a diagram this is the website http://a248.e.akamai.net/pix.crutchfield.com/manuals/110/110xa2100.pdf and look on page 5 it will show you. please vote and leave high marks. Thank you and I hope i answered your question
Jul 30, 2010 | Jensen XA2125 Car Audio Amplifier
My name is Noah. I have a Volfenhag zx 7150 2 channel amp, and I was wondering if I could use this amp to run my mids and highs. And if yes, how would I run the wiring?
Hello violentj_1_u,
Yes, the amp can be used to power normal speakers on 2 channels.
The best way to wire the amp to a stock receiver (head unit) is to use a pair of wiring harnesses, one the standard harness that plugs into the vehicle wiring, the other a "reverse" harness that plugs into the stock receiver.
First remove the plug from the receiver and plug in the "reverse" harness. Run the speaker leads from the reverse harness to your amp inputs or to a line output converter (LOC) and RCA's to the amp. Then run the amp speaker outputs to the standard harness speaker wires. Plug the original receiver plug into the standard harness and splice the remaining wires, 12V constant, 12V accessory, ground, illumination, etc, together. Connect the 12V switched wire to your amp remote terminal.
Hope this helps.
Aug 25, 2009 | Car Audio & Video
What is the wire diagram for the 3way bx35 boss crossover
Hello rew_smith,
The wiring diagram is silk screened right on the top of the unit. If your diagram is missing or obscured, you can get one directly from www.bossaudio.com.
The first 3 pairs of connections for subwoofer, front, and rear inputs coming from your receiver or head unit. Top is left channel, bottom is right channel. The 2nd set of connections are the outputs and matched in function to the first set. These are connected to your amp(s).
To the right of the input/output connectors are the 12V +, remote and ground screw terminals. The 2 switches and 9 controls allow you to set the high-pass frequency and output levels for the front and rear channels, and the crossover frequency, bass boost, phase, and output level for the subwoofer.
Hope this helps.
Aug 23, 2009 | Boss Car Audio & Video
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Jul 27, 2009 | Pyramid Audio Players & Recorders
PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
May 24, 2009 | Jensen Car Audio & Video
Audiovox AMP522A Car Audio Amplifier Logo
424 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
