Question about Olevia Kolin DLT2711M 27 in. LCD Television
Volume sticking?? My friend has the same model I have and they were purchased together on the same day about 2-3 years ago. She has had problems once under warranty for the same problem and now again, of course, not under warranty anymore. Syntax tells her it would cost $500 to fix it, where she could purchase a new one for that price. The problem is that when it is turned on, the screen is blue with the VOLUME bar. The volume turns itself all the way down and that is it. You cannot do anything else. I've tried to reset it, tried manually turning it on (without the remote) Thinking it might be the remote, but nothing. I can try to fix it for her but I have no clue when it comes to TV's. Computers no problem, but I never worked on a TV before. Is it a matter of replacing a part, and if so what do I need?
  • 689 Answers
Issue that you have explained can be related to volume control micro switch. Sometimes due to humidity or stuck contact volume goes up without user's control. You may try to pull the volume + button and exercise the contact. replacing micro switch is really low cost like a dollar. but soldering should be done by a skilled tech.
There is secondary possibility that controller IC might be malfunctioning, It will not cost more than $20 to replace the IC.
Please post if you have further questions.
Good Luck
Posted on Jan 27, 2008
My fujitsu heat pump died three days ago, purchased 6 years ago so warranty now expired. Service agent who sold me the unit suggested this model has caused many problems ''horror stories he said'' for his...
Yes you can check these out at Consumer Report.com. You can also order you a new unit for about 1/2 price on line. Just type in Air Conditioning mini splits Google this. I bought 2 ton heat pump on line from Amcore for 1100 includes pipe and all the wire you need. Russ Included shipping.
Jul 22, 2009 | Heating & Cooling
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
I have a Panasanic bread machine, Model BT 65P, we received it as a gift in 1993, I liked it so much, about 2 years ago, it didn't work right, it is like it punched the bread again just before baking it. ...
I would say reading this site and from my own model of breadmaker - stick with a Panasonic. There are so many problems listed for other models. I have had mine for about 15 years, make a loaf almost every day and they still turn out great every time. They update the models from time to time, but basically they still look and function similarly.
May 02, 2009 | Panasonic SD-YD250 Bread Maker
Coolent leak... 96 dodge caravan
if you get an overflow through the resevior it's often times because the thermostat with stick shut causeing excess pressure. seeing is the car is not overheating this means that the trhermostat is opening but when you get that overflow it's sticking i would replace the thermostat as soon as possible to resolve this issue
Apr 26, 2009 | Dodge Intrepid Cars & Trucks
Sounds like only one amp is working. Then after a few minutes the red light goes on and the unit shuts down.
90 % of these types of problems are caused by faulty leads .... make sure that you have correct speaker cables and not just a regular guitar cable
Nov 08, 2008 | Fender Passport Deluxe 500watt Sound...
Replaced RAM; PC keeps shutting down?
2 suggestions:
1. Make sure the CPU cooler is on properly.
2. Check your power levels. I had a computer which did this. Turned out to be the PSU which eventually died. A different PSU has had the board going for 5 days now, instead of 1 day or just a few minutes.
Aug 23, 2008 | ASUS AI Lifestyle P5N32-E SLI...
Dual head unit help!
You can try contacting the manufacturer to see if it can be repaired.
When you have this type of problem, it's generally due to the rotary encoder failing. It's unlikely anyone else will have parts.
Dec 22, 2007 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Olevia Kolin DLT2711M 27 in. LCD Television Logo
91 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
