Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Bosch WFF 2001 wasing machine
By fixy241 on Jan 26, 2008
Taking about 2.5 hours to do shortwash water not getting hot
Comments:
Jan 28, 2008
- Dear Friend water hoses are clear and water is getting in to drum OK. Also took out heater element and this is OK, so put back. Machine is running now but water is still not getting hot.
Jan 28, 2008
- I took the heater out and connected it to the mains and it got hot quickly. There were no holes in it or burn marks. Cant measure the amp draw
Jan 28, 2008
- Thank you for your help and advice. It turned out to be in the end one of the plastic spade connectors that connect to the heater element. It was broken inside. So I have soldered on new connectors and its working fine now. Thanks again.
David Smith
Best Solution
posted on Jan 26, 2008
Very Helpful)
Master_Tech
Rank: Guru
Rating: 88%, 782 votes
check the water inlet valve where the hoses connect shut water off and take the hot hose off look in the valve there is a small screen that maybe clogged if not report back and we can go in deeper
Comments:
Jan 28, 2008
- Ok then you are getting hot water into the unit .. the heater was the next step.....but what I need to know did you test the heater or just look at it they can break internally and on the outside look fine....You will need to test the voltage at the heater if you have voltage to the heater when in the cycle you will need to check the amp draw of the heater ..do that and let me know what you find.
Jan 28, 2008
- Are you getting pwr to the heater when the unit is on ??? you will need a test meter to go any deeper i can give you test points to check to see where the problem is,,,>> Do you have one??
PS: never dry fire a heating element it will burn out with in 30 secs of pwr being applied alway test submerged
Jan 28, 2008
- Great news plz rate me on this solution Thanks Gary
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
the washer sounds like it is spinning but it does not. clothes are very wet
Answer
la mia lavatice dwd/s1011/1012/1013 va in protezione l e e non parte il lucchetto di chisura porta... (More)
Answer
Our Zanussi Washer Dryer smells funny when drying and leaves the same smell on the dry clothes, the... (More)
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , IL
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
