Question about Zenith B27A11Z 27" TV
It won't turn on
My t.v. turned on for a minute then it shut off and it won't come back on, and if it needs a fuse, where do I get and put it
  • 1 more comment
  • Rhonda Ellis Jan 31, 2008
    It makes a clicking sound. It's as if someone is quickly turning it on and off. I also smell something burning; a burnt rubber smell.
  • Rhonda Ellis Feb 01, 2008
    Thanks so much. I'v decided to have a professional to look at it.
    With that burning smell, I don't want to take any chances. I'm gonna take your advice. Thanks.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Does it still keep turning on and off? If so, its unlikely that it is a blown fuse. A blown fuse would make the set completely dead and it wouldn't come on at all.
    - Jim
    Genius:
  • 1,694 Answers
Shorted cap Location # 3213 = .01 / 3KV
Shorted diode # X3204 = NTE 519
Burnt resistor R2925 = 1K 1/2 watt
Flyback usually ok..................................................T.
Posted on Feb 05, 2008
  • 2,130 Answers
The smell of something burning is not a good sign. The clicking sound you are hearing could be a relay or breaker kicking in and out as a result of whatever is wrong.
This could be cause by:
1. A problem in the power supply.
2. A problem with the Horizontal Output Stage.
3. The Flyback transformer.
Someone gave me a TV once that had the same problem. I determined that it had a bad flyback transformer. I replaced the transformer and the TV worked about 5 secs before I saw some black smoke come out of the new flyback. I turned it off right away and realized that something else was bad that caused the original flyback to burn up. The same thing was causing the new flyback to go as well. It turned out to be a shorted, 50 cent hi-speed switching diode. Fortunately, because I had turned the set off quickly when the 2nd flyback started to smoke, once I replaced the diode, the TV was fixed.
If you want to get it working again, you'll need to have it serviced.
Good luck,
- Jim
Posted on Feb 01, 2008
  • SHARCNET-USA
    SHARCNET-USA Feb 01, 2008
    You're welcome! Good luck and please come back and let us know how it went.
    - Jim
  • prasad krishna
    prasad krishna Aug 27, 2013
    JIM PLS TELL ME THE DIODE CONFIGURATION
Why does my 2005 chevrolet classic theft system keep coming on and then the car won't start afterwards unless reset by turning the key to ACC for 10 minutes then the car starts?
If you have a spare set of keys try using the different key. The identity chip in your key may be shorting.
Otherwise the "Reader" in your ignition switch may be cutting out. This puts it into an activation loop.
Nov 08, 2012 | Cars & Trucks
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
I have a 91 olds supreme 3.1 v6 it shut off and won't start back .... It starts but won't turn over.... And when turn the key back off it's blows the dis fuse wich mean direct ignition system...
Check the coils that have been replace for bent or broken prongs that plug into the ignition control module and if nothing looks damaged then i would think the ignition control module is faulty.Replace ignition control module.
Jan 21, 2012 | 1991 Oldsmobile Cutlass Supreme
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Television is about 16 years old. It shuts itself off. We were able to turn it back on for quite a while but now it won't turn back on. Wondering if it would be worthwhile to fix? Thank you!
I personally would not invest money into a 16 year old projection tv. But I would check the AC fuse and put one in to see if it would come on if it was bad.
May 19, 2011 | Hitachi Televison & Video
Whenever I try to play my Super Smash Bros. Melee game with 2 players (me and my dad),It always automatic turn off. I tried every combination of black and white controller,but no working. WHY IS THIS...
Power Light Shuts Off
If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Feb 27, 2011 | Nintendo GameCube Console
My Nintendo Gamecube seems to reset by itself about every 30 minutes, can anybody help?
If the power shuts off during game play or resets after 30 minutes after the system is turned on then turns off and won't turn back on or the fan isn't working, the system needs to be repaired then. This problem that you have might be the fan thats causing this problem then.
Jan 08, 2011 | Nintendo GameCube Console
Turns off automaticly
  • Power Light Shuts Off
  • Sep 27, 2010 | Nintendo GameCube Console
    Power button failure
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Engine rotates but will not start. I have spark and can hear the fuel pump relay click, but I don't know if the fuel pump is working. T in Georgia
    the only method that work was pulling the fuel pump fuse,wait 1 minute, crank her with out your foot being on the gas for 15 sec. Put the fuse back in , and start her up normaly. 1 st attempt she started but cut off, redid the process over , got in started her up normally, but had my foot 1/4 way down on the acclerator. She started and feathered the gas til she was fully operational. Let her stay on for about 10 minutes then took her out for a good long spirited drive.smile.gif
    Jul 30, 2008 | 2000 Mazda MX-5 Miata
    Zenith B27A11Z 27" TV Logo
    125 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
