Question about Dryers
Dryer have a maytag dryer, it is leaving black marks on my clothes. what could be causing this?
  • woodbug Jan 26, 2008
    I manually spun the baffles, they made like a grinding noise, like
    metal to metal? And I did hear something loose moving around. No
    crayons left in there, but black marks on a pair of beige pillowcases I
    dried.
  • Anonymous Mar 20, 2014
    model nomdet236ayw
  • 770 Answers
Nothing in the dryer i.e.crayon left in pocket?? there is no black grease used in the unit only White lithium style.. I dont think it came from the inside of the mach ...Best bet is to clean the tub out mild soap and a damp cloth it should go away. if not the peice maybe stuck in the baffles manually spin the drum do you hear anything rattling around?? Let me know
Posted on Jan 26, 2008
  • Gary Davd
    Gary Davd Jan 26, 2008
    could be the bearing going out and the dust (like your brakes on your car) is getting sucked into the dryer area.. If the unit is older that 5 years you might be best off to call in a tech and have them service it anmd delint it then you can have the brearing checked at that time
Dryer eating clothes
It may be running way too hot. If the filter is clean there may be a thermostat issue.
Mar 19, 2014 | Dryers
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer leaving small black marks on light colored clothes
Disassemble and look for lint issues, your description could be caused by burnt lint coming off of the burner.
Apr 22, 2011 | Maytag Dryers
Maytag gas dryer about 10 years old leaving black smudge marks on clothing. The wheel was hanging up on the dryer drum. Could there be other causes for the smudge marks?
your clothes are getting caught between the drum and the rim due to bearings out of the wheel guides. These guides are what the drum rests on when it is turning. Most dryers you can access these guides by taking the front off the dryer. Not a big expense just a little difficult to get to .
Apr 12, 2011 | Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
Dryer squeeking while tumbling & leaves black smudge on clothes
it sounds like a drum support roller is going bad or the belt idler pulley. i think maytag has a kick panel on the bottom that can be removed. look inside with a flashlight and you may be able to see something. if not, you may have to take the drum out to get a really good look. make a note and study how the drive belt serpentines around the motor, pulley, and drum so you can get it back together.
Oct 20, 2009 | Maytag Dryers
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Black Marks on Cloths
either the roller are degrading or the belt the black is caused by the grinding of the dryer as it spins and has no cushion left replace the rollers
May 03, 2008 | Maytag MDG2706A Gas Dryer
Dryers Logo
446 people viewed this question
Top Dryers Experts
Marvin
Marvin
