RCA Projection TV won't turn on
TV was fine at bedtime no problems noticed. In the morning I would press the power putton and the green led light would light and then immediately fade. Nothing on the screen.
  • bigsky21 Mar 07, 2008
    Mine has the same problem.Was fine, we turned it off for about an hour, turned it back on and the green light comes on for a couple of seconds then goes out. Sometimes blinks on and off a couple of times, sometimes just stays out.
I am having the same problem right now did you guys find out what is was please let me know thanks
Posted on Jun 14, 2008
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then should work.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sorry, here is the original post.
When you press power does the led light at all? That chassis has been plagued with bad flyback causing dead sets sometimes the led will flash 3 times slowly then go out. Other times it will make a soft short hiss. Does your set exhibit any of these signs?
May 12, 2008 | RCA P52926 52" Rear Projection Television
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Cutting off at different intervals
it could be high voltage cap located by flyback,if you have back off of tv and turn tv on,you will see green led's turn on,(on the board)if they turn off there is a small blue high voltage cap hidden under glue(i believe it's a 102 cap)that would be the one change,99% of time that is what will fix problem
Nov 28, 2007 | RCA HD52W56 52" Rear Projection HDTV
Phillips 60'' projection hdtv wont turn on
Question do you see green led or light when pressing power button? If you can also listen for a high pitch noise coming from back of set. This would be an indication that the set has powersuppy problem or high voltage problems. If the set is dead and no noise then maybe fuse or open circuit.
Aug 13, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
262 people viewed this question
Top Televison & Video Experts
