Question about MSI 915P Neo2 Platinum Motherboard
Front panel connections
I have msi 915p neo2 motherboard (not sure its platinum) bought for a while ago. when i installed watercooling had to pull out jfp1-2 connections to the frontpanel an i thought it was a whole plug instead of 4-5 several plugs :/ done was done so now i cant get any respons to the motherboard or anythin so i think it must be the frontpanel connections. any1 can help me find a website with pictures? i readed somewhere but there it explained eith colors of the cables but some dont match. plz help...
  • ali_deg Jan 26, 2008
    hi. since my search on the net for a selution to the prob i have. ive learned how to define my problem little more specific. so from mainpanel it supposed to come 4 diff wires to jfp1. mine is only 3 dif jumpers instead of 4. since i couldnt remeber which was what
    i didnt have all of the jumpers comin from frontpanel but comp worked fine. what to leave out so i can start my comp. plz and thx
    Novelist:
  • 113 Answers
The manual shows the correct pin outs, and can be downloaded here:
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=585
Posted on Jan 26, 2008
  • Anonymous Jan 26, 2008
    As far as I know the only jumper you NEED to have is the power switch itself. Of course if you don't connect the Reset cable to it's pins your reset button (if you have one) won't function but the computer will. If you don't connect the HDD LED cable, your red light won't flash when the hard drive accesses (assuming you have such a light), but the computer will still work. And the if the Power LED is not connected you will not have a power light (again, assuming your case has one) won't work, but again, the computer will.
    With that said, the power switch uses jumpers 6 & 8 of JFP1
6ya staff
SOURCE:
Hi i have a desktop computer motherboard neo2 915G with dvd rw-dl ND-4570A. I am trying to install windows xp. Just before it reboots it always goes into the fatal blue screen contact admin etc etc. I...
Have you tried booting in to "Safe Mode", your Blue Screen could be caused by wrong driver or other hardware issue...Booting into "Safe Mode" will load minimal drivers hopefully bypassing your problem.
The Blue screen also display code that can help you troubleshoot your problem, this info is displayed near the bottom of the screen...
Feb 22, 2011 | MSI 915P NEO 2 PLATINUM INTEL 915P CHIPSET...
Tip
Troubleshooting Guide
Click HERE to go to the online troubleshooting guide.
on Jun 03, 2008 | MSI 915P Neo2 Platinum Motherboard
Laptop will turn on, but can't load recovery or driver disks and if i don't use those i get a disk read error press control alt delete.
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Sep 29, 2010 | MSI 915P Neo2 Platinum Motherboard
IC7-Max3 with 2x512Mb OCZ PC4000 memory sticks (184 pin DIMM). Only registered 512 Mb. Vacuumed dust and cleaned. Now won't post. Cleaned memory sticks with eraser. No beep. Recovery path?
vacuums can cause static electricity. this may have damaged your motherboard in some way. you have to use a special anti-static vacuum when cleaning electronics.
Dec 26, 2009 | MSI 915P Neo2 Platinum Motherboard
I can't see the BIOS screen and this didn't check CMOS. i can't hear no beep.
Reverse the two-pins connecting the PC Speaker to the motherboard.
This can make any "beep" much louder.
Try a different power-supply, to ensure that your current power-supply is NOT the problem.
Remove the RAM and the video-card, then start it up.
It *should* "beep" to complain about the lack of RAM and the lack of video. If not, and the power-supply is OK, then the motherboard has its own problems.
Dec 02, 2009 | MSI 915P Neo2 Platinum 54G Motherboard
What is the socket for this motherboard and what cpu's can i use in it
http://global.msi.com.tw/index.php?func=cpuform will tell you but is the board revision a or 1.0b? Get that off the board itself and you are away.
Jul 05, 2008 | Computers & Internet
Installing new ram...wont work
Go HERE for troubleshooting guide. Scroll down to: Stability Problems - Memory Issues.
Beep sounds and their meaning
Hi All PC do what is called a POST a Power On Self Test and emit different beeps according to the make and model of the BIOS loaded. You can check out what they mean for different BIOSes here http://www.xmission.com/~comphope/beep.htm. This site lists the different post codes etc by the different bioses. So you will need to know what BIOS your PC is running just check the black screen at starup before any windows info comes up and look for something like AMIBIOS or AWARD etc, you can pause the screen so that you can read it more easily by pressing the pause button on your keyboard, this is normally the last key on the top row on the right. Hope that helps
Sep 04, 2006 | MSI 915P Neo2 Platinum Motherboard
MSI 915P Neo2 Platinum Motherboard Logo
187 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
