Question about Nintendo Wii Console
Funny noises When we turn our wii on it is making really odd noises - like a crackling sound. it started off really quietly but is getting louder. the games are still working
  • 2 more comments
  • mkburns Jan 26, 2008
    it is coming from the actual wii - its like a vibrating noise
    yes only does it when there is a disk inside, tried all my games
    thanks, tried it makes it a bit quieter. gonna clean the games and try again and will see bout getting it repaired. will be lost without it
  • johnseals Nov 08, 2008
    My WII system is making a funny grinding noise.
  • 112 Answers
Is the noise from the PSU brick or the unit? Or is it coming through the TV with the sound from the game? Sounds like something is shorting in the PSU brick - if so it will eventually stop working. Contact nintendo if under warranty still or source a replacement PSU on ebay etc.
Posted on Jan 26, 2008
  • 1 more comment
  • fluffy cat Jan 26, 2008
    Is the noise only there if a game DVD is inserted?
    Ok, either the disc clamp is off-centre so the disc is wobblying slightly while spinning or there is something catching on the disc as it spins. Try lying the unit down / upside down and see if the noise goes away.
    Also try having it on it's side as you insert the disc, then putting it the normal way up in use.
No video but sound
its the bulbs and or soder connections loose needs resoldered. mine was a 60" and cost 893.00 to fix it.
Aug 18, 2014 | Televison & Video
I have a 2001 pontiac grand prix gt and it makes a squealing noise, and when i accelerate it gets louder and more whiny. I have replaced the belt and it still makes the noise. If the car is started and not...
It sounds like a belt thats slipping. You have a sticking puley somewhere, take off the belt and rotate all of the pulleys. Usually its an AC compressor pulley so pay special attention to it. The whining noise that it makes while turning, is it the same as the squealing noise? If so it could be a problem with the pump, check the fluid level and see if its an odd color or has an odd odor (like burnt or black). Hope this helps!
Nov 26, 2010 | 2001 Pontiac Grand Prix
Does not read the disc and makes a funny noise
If there is a bad noise coming from inside of your Wii when you are trying to load a game, either there is something stuck inside of the DVD drive or a part has fallen out of place. If you feel comfortable with it -- open up the Wii and check things out. Make sure the kids didn't put anything in the drive. If you're not comfortable with it, the following website does Wii repairs and sells the whole DVD drive unit for the Wii:
http://store.richspsxparts.com/wiiredvddr.html
Nov 17, 2009 | Nintendo Wii Console
96 blazer dies at during braking with less the 1/4 tank of fuel or will refuse to start while parked on a nose low incline
possible fuel pump and/or incorrect fuel reading...these senders in tank can give false reading to gauge.key on-engine off runs pump for 3 seconds...listen to the pump in a quiet place like a closed garage and alot of times these pumps sound odd when failing like a louder whining noise than normal. turning the key off for 5 secs will reset and run the pump once again when you turn key on but do not crank. fuel pump is fairly common failed item for this make and model.Replacing sender while servicing pump is reguarly done as well.
Jul 09, 2009 | 1996 Chevrolet Blazer
My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Car makes funny noise upon starting on very cold days
Have your power steering belt checked and adjusted, or replaced if worn.
Jan 20, 2009 | 1998 Plymouth Breeze
Tv won't turn on. tv made a loud noise and picture went funny.When we tried to plug it later,it just kept making a crackling noise.Does it sound like something that can be fixed?
Power supply is blown. Google it, check ebay (with tv model name) or just part it out and get a new one. You can also buy these used for really cheap off of craigslist.org
May 28, 2008 | Sony KP-EF41 41" Rear Projection...
Wii making a funny noise when loading discs
continuous clicking could be a few gear-related issues:
-if the pinion gear is slipping against the rack for the disc-load mechanism, you can try to re-align the rack (hopefully it was just forced out of place and can be clicked back). i would suspect this if the noise is relatively quiet and very fast.
-if something is jamming the load mechanism, like the rack is stuck, the pinion gear may be clicking over the teeth of the rack. i would suspect this if the noise is loud and slower.
This is a common defect with Wii's and seems to be getting worse. I suggest you either take it in for warrenty if its covered or have some one replace the drive for you.
Apr 30, 2008 | Nintendo Wii Console
Vizio 42" LCD HDTV audio issues
First of all go into the audio menu settings and turn off the "surround" feature off and that should fix the voices/music differences. Does the craking sound appear while watching any sorce such as cable box,sat rcvr or DVD player? If not isolate it to that input and maybe that device is giving the problem.
Feb 21, 2007 | Vizio L37 Television
Nintendo Wii Console Logo
213 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
