Question about APC Back-UPS Pro 650 UPS System
My APC keeps beeping.
I just purchased my APC UPS ES 725 and when I turn it on, it starts with a short beep to let me know that it powers on, and it worked fine for about 4 houars. But after that, the alarm went off and it would not stop. Ever since that, it will only alarm. I don't understand it.
  • 2 more comments
  • Nonie Stager Apr 10, 2008
    Yes, this is the 3rd one I have had--they keep replacing. I have never had this problem before. Everything is connected as it should be. There are no brown outs and everything is plugged in accordingly. Depending on the day, it will beep all day. Hate it!
    Comments have not been helpful. Have done all that you are suppose to do including connection, downloading software, etc.. Mine keeps beeping and APC has exchange it twice. I don't get it...can't be the battery and cannot be a brown out cause my system doesn't go down. Maybe there is a potergeist in the wall. Doesn't happen everyday--some days-all day, some days--one to four hours, some days--not at all. Clueless with APCs.
  • Anonymous Feb 12, 2009
    I have the same problen..seems like a lot of people do.and they send a novice to tell us to check the plug...geezx..isnt amareican buisnes going down the tubes!
  • Jocelyn Viau
    Jocelyn Viau May 11, 2010
    Firstly, have you connected the UPS cable to your computer and installed the PowerChute software? This software will be able to tell you more exactly what it going on.
    Secondly, on the UPS, is the "Building wire fault" light on? If it is, then it means that your power outlet is badly installed. It may be because the polarity was inverted or because the ground is not connected.
  • 1 Answer have unpluged or dislodge you power cable from the outlet or from the power plug shuye at the back of your ups.. double check all the plug and re plug all your power cables !!!! make sure they are tightly pluged in and firm in their outlets..
Posted on Jan 28, 2008
If you connect it up to a Windows computer with the supplied (goofy-looking) USB cable and install the APC Monitor progam "Powerchute" available on the APC web site, you can set all the activity levels and tell it just when to beep the beeper, or turn it off completely. I have two of these in my house, and have set them to never beep. The cable is goofy because it is USB on one end and a network-type on the other end.
Software Firmware
Jun 28, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
Alternating green and orange light with constant beeps
Verify that the usb to ups cable is pluggled in properly. Also you may not have a good ground. Disconnect the ups and plug it in another outlet to test with nothing else plugged into it, to see if it still beeps. You can also try and upgrade the ups software from
Jun 25, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
What does it mean by the beep sound from the UPS ES 350 unit?
Ok, 3-4 years is a much as you can expect from an ups battery so replacement is indicated. The beeps are letting you know the battery is not able to keep up with demand. So either you have recently added to the system or the battery/s failing.
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
These UPS systems do a self check everytime you press the power button. If the voltage in the battery is too low, you'll get a long drawn out beep. A new battery should solve that problem and it is even economical with a unit this size. Here's a link:
Simply remove the single phillips screw on the bottom of the unit and remove the battery cover. Replace battery and that's it. Very simple to do.
Apr 14, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
UPS shuts off intermittently and beeps
More than likely it just needs a new battery. If the power is sagging (called a brownout) the UPS is trying to switch over to the battery to keep the power consistent. The beeping is probably a code that indicates there is an issue with low voltage on the battery. New batteries are around $20-25. Here's a link to the replacement battery:
Hope that helps.
Jan 21, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
The Problem is the UPS beeps.
Hi friend,
You should on your UPS power other after some time beep will continue...
Dec 25, 2009 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
1) Switch Off the UPS and unplug all Loads (like System, Monitor etc.) from UPS.
2) Switch Off the AC Power (Input Power to UPS).
3) Press the UPS Power Switch constantly unless you hear 2nd BEEP Tone. As soon as you are hearing 2nd BEEP Tone, Release the Power Switch.
4) This is COLD START of all APC UPS that will reset any internal problem.
5) If, however, the problem persists, contact APC.
Jul 23, 2008 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
I have my apc beeping all time with and with out battery,I need a solution. Thank..oscar
Jul 07, 2008 | APC Back-UPS ES 725 Broadband (BE725BB-TU)...
APC Back-UPS Pro 650 UPS System Logo
9,956 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
