Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Ge side by side 5yr old Refrigerator
Left freezer door open a crack for three days while I was gone. returned to find water all over the floor and the back of the freezer frozen over with ice crystals. I unplugged it for 48 hrs to defrost and plugged it back in. it worked for 3 weeks and then started leaking again and not cooling properly again. what do I do? and how
  • stephkronen Jan 26, 2008
    i can't get the nuts off the back
    okay, I got the nuts off but I can't tell which black box you are referring to, can you be more specific? thanks!
  • 770 Answers
You will most likely have to replace the main controller board.. I have had the problem come up before and the GE boards are known for going out..The board is located on the back right side of the refrigerator has a cover plate about 6" across and 8" high The most likely failure is the relay to turn on the compresser (it is a small bk box on the board) you can unplug it and open this panel plug it back in and tap the relay with the back side of a screwdriver and see if you hear the compressor running.. Let me know
Posted on Jan 26, 2008
  • 1 more comment
  • Gary Davd
    Gary Davd Jan 26, 2008
    Well did it work??
  • Gary Davd
    Well at least i tried............... best to call a Service tech
  • Gary Davd
    It is a relay about 1.5" x1' square on the board itself tap on it lightly to see if the compressor comes on
CSH22GR- water on floor, at left front of refrigerator (looking at it) approx. every other day. ? source ideas?
greetings,
The freezer floor may be frozen over with ice due to a clogged drain..the drain gets froze up and the water actually runs over the floor of freezer and goes out the door..if froze up..defrost and open drain..
Jan 24, 2011 | GE 21.9 Cu. Ft. Side-by-Side Refrigerator...
We left the freezer door open all night...now the refrigerator will not get cold?
the freezer needs to be shut down for a whole day in order to defrost the evaporator coils completely.
this can also be done by removeing the rear panel in the frezzer and using a blow dryer until all the ice is gone and then the unit should return to cooling normally
Jun 03, 2010 | GE GSH25JFR Side by Side Refrigerator
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Side by side runs constantly.
The timer that controls the defrost cycle/function, may have failed and there may be no defrosting occurring. If icing of the coils due to the missing defrost cycle, there may not be enugh circulation left to keep the thermostat happy.
Try defrosting it manually (I know, it's a pain - aren't we spoiled?) and see if the compressor then cycles for a few days before it starts running continuously again.
And for Dr. Fred, the above suggestion about trying manually defrosting applies to your problem too.
The exposure to overnight moisture (ice accumulation) may have interfered with the automatic cycle.
Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Left freezer door open-not cooling
Steph,
Your defrost timer may be stuck! This device turns the compressor off and turns on a heater to defrost everything. The timer is located in the back of the refrigerator section on most units...usually near a vent. You may see a small shaft with a 'one way' end that looks like the business end of a drill bit about 1/4 inch in diameter. If possible, turn it (probably) clockwise about half a turn. That may fix it. Wait and see what happens. If the compressor starts...you're on the right track. If not, you'll need to replace it. There are usually a few screws that you'll need to take out to access the timer.
About the ice maker...are you sure you've taken all the packing material out of the unit? Have you plugged in the motor unit? Use care when going near these items. They are mechanical, sharp and you can get injured. See if your manual is available...or online.
Nov 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Nov 27, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Loud noise and lots of ice buildup in freezer
Possible that door has been left open a few weeks ago, sollution, turn off defrost overnight with the doors open, turn on following day, unit will work ok within 24hrs. Regards Advisor
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
48 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
