Question about Whirlpool LEQ8000JQ Electric Dryer
Operating Thermostat Burnt out Twice
I've been having a problem with my dryer not producing heat. I tracked it down to a faulty operating thermostat and the thermal cutoff. After replacing the operating thermostat and thermal cutoff the heat worked fine for about 10 minutes and then only cold air was blowing again.
I checked the newly replaced operating thermostat and it had burnt out again! The thermal cutoff seems to bo OK, now. What could be causing the operating thermostat to burn out like this?
  • 3 more comments
  • Matt Gurzenski Jan 26, 2008
    When I run a load without the vent, Can I run a load with the wires that go to the operating thermostat taped together to bypass the thermostat and avoid burning out a new thermostat, or will that cause more damage?
    Also, I did try to clean out the vent after it burnt out the second time. There was a bunch of lint, but it didn't seem to be excessive or blocking anything.
    See comments above.
    Master_Tech thanks for your response.
    It's a six year old dryer, I am going to delint it now. No, I don't think anyone has ever opened the dryer to delint it.
    Yes, the exhaust is coming out strong.
    I've attached a picture which shows how I can get hot air to flow through the dryer by removing the purple wires going to the thermostat and connecting them together with electrical tape.
    I'm guessing it's not safe to run the dryer like this, but do you think I can run a few loads of laundry with this setup? Also, I replaced this is one of the parts that I replaced last weekend.
    Thanks for your help!
    I tried connecting the purple wires back to the tstat and tried running a cycle with timed drying and got only COLD air.
    My e-mail is mgurzenski at hotmail dot. com
    Purple wires connected to tstat and Red/Red White wires = COLD air on timed drying and "Normal" accudry mode.
    Genius:
  • 3,587 Answers
Ok..move the dryer to the desert..the air there is much warmer..
Posted on Feb 20, 2008
  • Patrick Michaels
    Patrick Michaels Feb 20, 2008
    this is a guy that ought to join as an expert, eh?
    Genius:
  • 3,422 Answers
Start the dryer in a cycle and watch the burner area. You should see the ignitor start to glow. After a few seconds of it glowing you should hear a click and the gas come on and ignite. If the ignitor does not glow, look on the top of the air duct to the left of the gas valve. You will see 2 temp sensors. One will be white with 2 small blue wires going to it. UNPLUG THE DRYER NOW Remove the wires and connect them together. BE SURE THEY DO NOT TOUCH ANYTHING ELSE
Plug dryer back in and start dryer again and see if ignitor glows and burner lights. If it works now, you need a new thermal fuse. You also want to make sure the vent duct is not clogged with lint or the hose is not kinked. I DO NOT recommend that you run the dryer with this bypassed. It is a safety mechanism.
If this is not the problem or your dryer is not front servicable, post back and i will try to walk you through the problem.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 06, 2008
    Master:
    Sergeant:
  • 440 Answers
Yes u can run few loads way u are just watch it worse happen power breaker wil go off ok might be fulty thermal state not taking the reg wire config ok but yes do few loads it wont hurt u thx nick
  • nick helpap
    nick helpap Feb 06, 2008
    also 6 yrs old thats like new cheak controller board also for short outs thx nick
  • 61 Answers
I belive there are people out there who fix problams if you look in the yellow pages or phone book look for dryer repair i know people on here should help but it is easier if people could see the problam.
Posted on Jan 26, 2008
  • 770 Answers
Have you checked the venting ???? the heat could be backing up into the dryer causing it to burn out.?? Run a load with no vent on and see if it is ok..JUST a NOTE:the operation(cycling) stat the Hi limit Stat and the Thermal cutoff are all diffrent The Thermal cut off is located on the upper part of the heating element housing...The hi limit is on the bottom of the element by the terminals to the heating element.. the cycle stat is on the exsh. ducting I just wanted to make sure we were talking about the same part
  • 4 more comments
  • Gary Davd
    Gary Davd Jan 26, 2008
    did you try to run a load with the vent off?? also the breakdown of any thermostat or thermal fuse is Heat related either caused by heat backing up into the system or lack of air floww you may need to open the dryer and delint it how old is it ?? has this ever been done?? is the exhaust feel strong coming out the back??
  • Gary Davd
    Did you do the things that i had asked so we can look deeper into the unit??
  • Gary Davd
    the wires you are taping off are for a little heater in the stat it is wired thru the moisture sensor first plug back in the wires and set on a timed cycle see if it works ok ... You may have a short in the sensor circuit causing the tsat to burn out...POST you email here and i will get you the service manual in PDF format
  • Gary Davd
    leave the purple wires on and jumper the re and red/white ones on the stat and retest
  • Gary Davd
    check your email
  • Gary Davd
    Wow you kill he here all the help i gave you on this machine and you rate my help 2nd best to a guy who advises you to call a local repair company ...GEEEEZZZ
Doesn't heat
what is it??
Oct 29, 2017 | Dryers
We think we need either ,a new heating elememt ,or a High limit thermostat ,is there some where I can get a diagram ,ofvthe workings of these areas
Heat circuit in dryers typically runs through timer, motor, heating element, operating thermostat, high limit thermostat, and thermal cut off. All of those can be checked with a meter. Also be sure there are no burnt or loose wires anywhere. And also be sure there is correct voltage going to dryer. And also be sure venting is clear from inside dryer to outside of house.
Oct 22, 2017 | Dryers
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
I have a Whirlpool electric dryer MOD WED5540S!) SER MU2124790 TYPE DWJR-ELE-2406026-FM54 the dryer runs good, but will not heat. I have checked the air flow and its clear. I've checked all...
Limit thermostat , heres how you check thermostats Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Whirlpool WED5500S Electric Dryer
I have a thin twin stacking whirlpool washer/dryer. The high limit switch is kicking off the element within 2 mins of running. So heating element heats up red hot, then clicks off after 2 mins. I have...
I think you are on the right track with a faulty high limit switch. When i serviced these units we always replaced the operating thermostat and the high limit switch together they came in a kit. The operating thermostat in theory should never let it get hot enough to trip the high limit switch, which is really just a safety backup for the operating thermostat. Get the kit and replace both, and also make sure your exhaust vent going outside has good flow at the outside vent,a restricted vent system will cause similar issues.. Good Luck
Oct 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
My dryer will run for about 20 minutes and then shut itself off. I cannot turn it back on for at least an hour as the 'done' buzzer will buzz and the dryer will not turn back on. Does anyone have any...
If it happens during the auto-drying cycle, the moisture sensor could be faulty.
If it happens during the timed cycle, the operating thermostat may be faulty. A faulty operating thermostat can fail to turn the heaters off and allow the dryer to get too hot. When this happens, the high limit thermostat will turn off the machine. After it cools down, it will start again.
Apr 28, 2010 | Dryers
I have a kenmore gas dryer that will sometimes heat up and the nect time you use it doesn't
Is it not igniting everytime or just heating up and shutting down early? If the ignitor, gas valves, and burner are operating properly, I would suspect a faulty high limit thermostat. This is a small round, black device mounted on a metal plate and attached to the internal ductwork with two screws. Test it using a multimeter or ohmmeter for continuity. It should have no continuity. If it does, it is faulty. Here is a photo of a thermal fuse and high limit thermostat for reference. Hope this helps and best wishes.
Aug 08, 2009 | Dryers
Unpredictable heat
hi i think you have problem with thermostat. t hermostats, the dryer temperature control switches, are controlled by the temperature inside the dryer or by the heat of the motor. One or more thermostats on the panel can be adjusted to control the temperature in the dryer. Operating thermostats sometimes stick, causing control problems. These thermostats are usually positioned near the exhaust duct bulkhead or the fan housing of the dryer. Remove the back panel of the dryer to get at them.
Before you make any checks, try tapping the housing of the thermostats lightly with the handle of a screwdriver. This may jar the contacts loose. Temperature control switches are located behind the dryer control panel, and the panel must be removed for switch testing or replacement. Here's how to test and replace the thermostat:
Step 1: To check the control panel thermostat, make sure power is off to the dryer. Test the thermostat with a VOM set to the RX1 scale. Clip one probe of the VOM to each thermostat terminal. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Step 2: If necessary, replace the thermostat with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
thank you .............please rate it
Nov 18, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Gas dryer
Welcome jessegonzales
Check the outside vent leaving your house does not have a screen on it.
Take the screen off. Even half blocked and the dryer will not dry well.
Possible solutions
1. Defective Heating Element
The heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
The normal method for checking a heating element is to check it continuity. With the element unplugged you can check the continuity from one wire post to the next. If the circuit is open, thent he heating element is faulty.
However keep in mind that the element could be shorted to the case as described above. In this situation it is possible to have continuity, but the element still be the source of the problem.
Let me know.
Please remember to leave a rating
2. Defective Heating ElementThe heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
the heating element is faulty.
3.Defective Thermostat
The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
4. Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
One of these will solve the problem!
Thank You
Huuum.
Jul 29, 2008 | Frigidaire FGQ332ES Gas Dryer
Dryer no Heat. New Thermostat Burnt Out.
sounds like you are replacing the hi limit thermostat try replacing it with the cycling thermostat as well
Jan 20, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
136 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
