Question about Alps MD 5000 Thermal Printer
Alps MD 5000
Recently bought one on E-Bay without user guide have windows XP on
one computer with available Paralell & USB ports
Windows Vista on another computer with USB ports
Is there any place I can receive step by step connections instructions
and installations
I am confused by the two ports on printer
thanks in advance for any help you can give
Ted
  • 1 more comment
  • rcladagh Jan 27, 2008
    Thank you for your help
    OK I did everything as described above on my computer with XP on it and now when I try to print a test page
    I am getting flashing error light any further suggestions
    can you help
  • rcladagh Jan 30, 2008
    while i appreciate the answers i received i still do not have my printer working anybody out there to help
    Genius:
  • 1,226 Answers
You should use only one connection;
first verify the connection of the printer, if you see 4 pins that is usb connect. if it s 24 pins that is parallel.
Firs you should install first the software: donot connect the printer. the installation prompted you to connect the printer. that is the time that your should connect and power up the printer.
After that follow the screen instruction. your on your way.
thesame thing steps in the parallel connection. just do thesame.
thank may this help.
Note: you should unistall the previous installation of the driver then restart the system and the proceed what im talking.
Posted on Jan 30, 2008
  • Emelio Navaja
    Emelio Navaja Jan 30, 2008
    Use only the USB port.
    Genius:
  • 1,067 Answers
So are uusing usb cable then go in printer options tell it usb cable not ltp port or parrelel unlesss uuse that port also download the latest software form website dont use cd
Posted on Jan 27, 2008
  • nick helpap
    nick helpap Jan 30, 2008
    all u gotta do use usb port its faster newer style ok all new computers have them most new one dont use parrele ports serial coms nomoree u can just go to website downloa dthe drivers for your model install it on whatever xp driver or vista driver if they have one out yet sum older printers dont
    Scholar:
  • 54 Answers
1. delete any MD5000 printer entries. *(I had no other printer entries defined)*
2. Use ADD/REMOVE programs to remove the driver.
3. Disconnect printer USB cable (one you bought on EBAY) My laptop has no Parallel port.
4. Reinstall Driver (I am using 2.2.4) specifying not to make it the default printer. For me the 2.2.4 install worked fine.
5. use the add a printer function to manually add the MD5000P. I pointed the install wizard to the 2.2.4 file created by the installation of the driver when it asked if I had a disk. for my computer that was:
C:\Documents and Settings\AMD64\My Documents\My Received Files\MDP224XP
5. after the printer definition was successful , I followed the steps from a
previous message in the ALPS group listed below listed below:
RIGHT CLICK MD5000P ICON, and open properties menu for said printer (this is the one you created manually)
click PORT TAB:
pick a USB port ( virtual printer port) from list *(the install set it to a
port of MD_LPT1 I selected USB001)*
DISABLE bi-directional support RADIO BUTTON,
click ADVANCED TAB:
click PRINT DIRECTLY TO PRINTER radio button,
OPEN PRINT PROCESSOR BUTTON on bottom of page,
from menu select ALMD224S (for print processor)
and DATA TYPE select RAW(FF AUTO).
I plugged the printer in a USB slot and printed test page and a color
photograph.
After this all worked I reset the USB port definition to reselect the bi-directional function. So I do run with the bi-directional mode
Note that Win XP itself will auto create a printer definition using a Microsoft driver "Alps MD-5000P (MS)" if you use this printer to print you will not get any of the ALPS functions.
But this seems to have worked for me.
I hope this helps you. I have only worked with an Alps MD5000 so I have not done this with any other model but the steps I think the steps could still apply because of windows requirements. I have not tried to install the driver on Vista so I do not know if it will work but it might.
Hope this helps.
If any of this is a problem you can contact me and hopefully we can work it out on the phone or chat or whatever
Good Luck
Why alps md-1000 printer not responding after driver installed
Can you provide more details about the problem? Will the printer print a self test page? What OS, computer, and cable connection are you using? The ALPS printers were designed to work with Windows 95 using a serial port internal to the motherboard. There is a driver that supports a USB port and Windows XP available. XP will automatically install the MS driver using the plug and play feature. The MS driver is useless and it shouldn't be used, but XP will default to it. Don't delete this driver, but rename. There are no native drivers for Windows 7 or higher.
Jul 15, 2014 | Alps MD 1000 Thermal Printer
Alps md driver error
For the ALPS printers, make sure you are using Windows XP SP2 or older. There are no Win 7 drivers and there can be problems with a Win XP SP3. Join the Yahoo ALPS group. In the files section they have a full description of the problem along with a work around. It usually is a conflict with the bi-directional communication and the LPT port. The LPT port needs to be motherboard based - not an add-on card.
I hope this works.
Nov 14, 2012 | Alps MD 5000 Thermal Printer
Can our ALPS MD 1000 printer work with Windows 7? We used it when old computer had Windows XP on it, but that crashed and bought HP with Windows 7 now... we need Alps to make waterslides for custom rod...
There are NO Windows 7 drivers for the ALPS MD printer. I've read that you can run an XP virtual mode on Win7 that allows you to use the printer. If you are comfortable tweaking the OS, it's a workable option. I picked-up an old (and cheap) laptop on Craigslist and printed my decals from there.
Sep 15, 2011 | Alps MD 1000 Thermal Printer
I have an alps MD400 and am running xp pro with drivers for xp and can't get the thing to print and need a trouble shooter
There are WinXP drivers for the MD-4000. You can find them in the files section in the Yahoo ALPS Group. There are some conflicts with the Windows XP (Service Pack 3) and the ALPS printers. It is best to connect to a computer running SP2 and has a parallel port. The ALPS group also has the Twain for the Scanner. The MD-4000 does require a carrier to scan things.
Dec 17, 2010 | Alps MD 5000 Thermal Printer
I'm looking for a vista or windows 7 driver for my Alps MD-1000
There isn't any Vista and Windows 7 drivers for this printer. The manufacturer still hasn't produced any. This is really sad because I have the same printer and I have to stick with XP just to be able to use it.
- HotRatchet
Dec 15, 2009 | Alps MD 1000 Thermal Printer
MD5000 to MACBOOK PRO problem
MAC is NOT my forte... however, I do know that ALPS offered THIS a few years after the MD5000 came out:
USB Interface Kit for the iMac OS V8.01 and Windows ($99)
You might find it on ebay etc. and be able to use it (no support with this printer on OS X!).
Apr 08, 2009 | Alps MD 5000 Thermal Printer
I am looking for win xp drivers for my alps MD 5000
I found a private indivdual that had an original installation CD with windows xp software  and drivers
Apr 01, 2009 | Alps MD 5000 Thermal Printer
Alps MD 5000P Vista Drivers
There aren't any.
You can try the XP drivers if you're using Vista 32, but there is just no way to use these printers on Vista 64
Apr 15, 2008 | Alps MD 5000 Thermal Printer
NEED TO HAVE INSTALL SOFTWARE FOR wINDOWS VISTA
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
http://tech.groups.yahoo.com/group/Alps/
Apr 08, 2008 | Alps MD 1000 Thermal Printer
Alps MD 5000 Thermal Printer Logo
307 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
