Question about Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic retractable lens problem
The automatic lens cap on my Panasonic DMC-LZ7 fails to completely open when unit is switched on. This started occurring shortly after I purchased the camera. I thought it may have been related to batteries, but I still have the problem with newly recharged batteries. It will retract fully only by forcing it open with my finger. Once open, it stays retracted. Any ideas?
  • 1 more comment
  • Anonymous Feb 12, 2008
    Mine started doing the saem thing after several months. I left it in the basement overnight, aound 48 degrees, and I have to tape the stupid lens cover open to usethe camera ever since. Its not the batteries.
  • mik_in_monta Jan 28, 2009
    My lens cover only opens a tiny slice when the lens comes out. I can use my finger to open it all the way, but when I let go it closes again. I am thinking of breaking off the lens cover pieces and using a case to protect the lens.
  • bbengtson Mar 21, 2009
    Lense cap doesn't open up all the way.
  • 53 Answers
If you need parts for your LZ4 there is a guy in South Carolina that sells good used parts at a reasonable price. I think his email is
Posted on Mar 12, 2008
  • 104 Answers
Well obviously if the camera still under guarantee, use this benefit...
Otherwise it is not too hard to disassemble your camera and try to repair it.
NOTE: this kind of machines were not made to be repaired when the damage is important. (that is why they are so cheap if you think of all you can do with them and the quality they usually offer). Normally only silly problems like mirrors, lens or any piece out off its place, maybe a broken little piece of plastic, a cut cable or missing screw would be something that can be fixed without new pieces which we do not have and an electronic weld station... I say this because when I go to a technician and he gives me a bill for the half of which a new machine can be purchased... I do not feel like something was repaired...
NOW there is a few screws that you must remove in the right order and place in a secure place, ordered and if you are not too skilled in repairs... also labeled because some of them are slightly different to the others. (just to remember where to put them back).
In cameras like LZ4 with 12X optical zoom and that "reflex" appearance, there is 3 screws on the base, 2 on one side, 1 on the other and you must remove that black one that hides in the center of the plastic structure that you can see when you look at the front with the flash open.
once you have pulled of the back panel be really careful with those two power cables, the one for the LCD screen and the other for the power section. with all the love of the world and a nice thin clamp get the little connectors off CAREFULLY.
Then with the same care take the data cables (flat cables) unattached (there is a little plastic piece that you must move to release them). Then put the panel in a safe place.
You are now looking to the printed board, the chips and stuff...
try not to touch anything rudely. There will be at least four screws that hold the board to the other structure, remove them first and the remove two more that you will see if you look at the upper center part of the opened camera just behind the board. Those two are holding the shutter button panel and the flash.
NOTE: the one on the right, that holds the shutter panel is longer than the other... REMEMBER THIS WHEN PUTTING THE PIECES ANS SCREWS BACK TOGETHER.
then almost all the camera will be able to be disassembled, NOW: TAKE CARE WITH THE FOLLOWING:
1. The flat cable for the Viewfinder is TOO Important and its not well attached, the piece of plastic that holds it firm is really thin and weak, be careful or your Viewfinder will be off. Take it out and then do the same with the flats on the middle lower and upper part of the camera, the flat cable which is up behind the board is a little hidden and must be released manually just by taking it out, IT has no plastic holder... but do not worry it is safe and easy to put it back if you are delicate.
2. The shutter and the mini USB panels both up and side can be released: the first one is attached to the board by one of these flat cables.
3. Finally there is a group of thin cables at the side of the viewfinder that may hold the board a little... just move them to get the board unleashed.
Once you have done it (if I am not forgetting anything) you will be
able to separate the board which you must treat very carefully.
now you see the lens cannon which can be separated too. The rest is just plastic.
The lens structure is simple but it is extremely important for the zoom function that this part is perfectly working. If you lens system is stuck you need to work on this part:
First you must do is find the little engine on the side of the cannon and take it out so you wont force and brake it when you move the structure. There are 3 screws or 4 that you have to remove to be able to get to the lens. Remove them and you will be able to access inside the cannon by moving the plastic roll. If you manage to understand how it works and after unlocking the stuck you find that nothing is out of place and there is no rare sound going in there. The problem might just be solved. But if you want to make sure so you wont need to assemble and do it all over again... try this:
the structure has two main parts: one is attached to the back part of the cannon and there you have a series of flat cables which you should not release. This part holds the engine that moves the system lens in and out. The other part is holding the exterior lens. These are linked by two metal bars which holds the middle lens inside the cannon. That lens is which usually gets out of place and must be put back on. To access this lens you have to move this zoom system till it gets tho a limit where you can gently release and separate both parts. Do it over a soft place like a rag or something like that to avoid damages if some part falls. Once its open you have to make sure all the pieces are holding the right way. The middle lens must slide freely through the canals in the tube and there is only one position for the two parts to be put together so you just have to use your eyes to assemble or disassemble the cannon. Once you make sure it is right you may manually move the zoom slowly in and out and there you will find if something is broken or suck, if everything is alright you will be able to fully extend or close the cannon. ONLY THEN you must put the engine and the screws back in place. If some screw does not want to enter something must be out of place.
Then you just have to put all the pieces back together, you have only to read this backwards to find out how. If this does not fix the stuck lens problem. You will have to spend some money with a technician and maybe replacing parts.
REMEMBER, if you treat each part with the needed care you wont have problems. So DO NOT FORCE any part, it is better to call for aid if you cannot do something.
if your are a good person I hope you succeed!
Posted on Feb 19, 2008
  • Carpenocte Carpediem
    Carpenocte Carpediem Mar 01, 2008
    Sorry! I stupidly wrote a wrong model, the solution is for LUMIX FZ4 and FZ like cameras. You know, this happens...
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
The lens cap of my lumix TZ7 no longer opens. thank you for the solution.
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
Aug 13, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
How can I clean the INSIDE of a Panasonic Lumix DMC-LZ7 lens?
Unscrew the entire lens assembly from the body. The inner lens cannot get debris inside it but the outside of it and the inside of the protector lens can. It's a good idea to do this cleaning in your bathroom with the shower on hot but not visibly steamy as this will cut the airborne dust by 90%.
Feb 22, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
Stuck lens on on lumix dmc-LX2
u could go to best buy but it might be cheaper to buy a new camera
Jan 13, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Same problem
there might not be a physical damage outside which will be easily noticeable but it if you have dropped it once hard the lens array which is a sensitive part gets defective. try tapping on the device while the camera is switched on. if it works then you are lucky. but if still the problem persists you have to take it to the service centre. it costs about 60$.
Jun 12, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic lumix 5.0
The TZ3 has a design problem with their new automatic lens cover, ie, manual lense cap on TZ1 was illiminated on TZ3.
Make sure your lense cover is completely retracted in front of the lense. If not, nudge it fully opened and see if this solves you problem. If it does, contact Panasonic with your problem. If not under warranty, tell them you want them to fix 'their' problem on your camers. Google it on the net and see how common this problem is.
Apr 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
Mar 21, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Panasonic Lumix DMC-LZ7 problems with lens extention/retraction
Dear I have the same problem with a DMC FX-55! A mess!! Any solution?
Jan 28, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic Lumix DMC-LZ7 Digital Camera Logo
268 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
