Question about Panasonic TX-28CK1 28" TV
Tv chirpping Hi i dont know if you got my last request as i got no reply. The problem is with my panasonic TX-28PL1 tv its making chirping noises i am able to solder so is their anyway you could point me in the right direction whats the problem and what needs replacing. Also the telly has been off now for over 3 days is this long enough to make sure their is no power left inside the telly that i need to worry about many thanks if you can help me ok. This isnt my expertise if you look at my profile you will see this if you need any help with my expertise let me know and i gladly help you thanks again
  • paul proctor Jan 30, 2008
    thanks for your help
  • 1,694 Answers
Check Horizontal Output Transistor...if shorted = replace it AND
the flyback transformer with Panasonic parts.If xistor is good,
replace flyback ONLY...............................T.
Posted on Jan 26, 2008
We have a Panasonic TV - Model TH-37PX60U (purchased 08/2006) that makes a "chirping" type noise periodically - sort of comes and goes. Any idea what this might be? Thanks, Mike G Pinellas Park,...
Sometimes that "chirping" is caused by loose windings on various transformers. You can usually isolate a particular transformer by pressing on it when it is "chirping" & it may stop "chirping" or the frequency my change. If that is the cause, you can A: replace the coil, B: replace the Printed Circuit Board, or C: Do nothing as it really isn't hurting anything but your nerves.
Oct 22, 2011 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic NN-H264SF Microwave oven starts with a chirp
No I dont think so, check that the wheels on the rotating ring are not seized up and dragging. These will make a chirp type sound as it starts to rotate or even when it finally comes to rest.
Please rate our help++++Thanks for using FIXYA
Oct 09, 2009 | Microwave Ovens
Noise from hitachi 42PD5000
The noise is coming from one of the plasma driver boards. There are 2 inside the set. These are essentially power supplies for the plasma itself and contain many capacitors. The noise you hear is some oscillation inside a cap or two. This is an indication that one or more components have drifted from their rated value. While the set will continue to work for a while, that board should be replaced. If the board fails, 1/2 of the picture will be blank or the set will not start at all. Call around to get the cost of that board. Please note that continued use of the set WILL NOT cause any harm. This is an annoyance only at this point.
Apr 29, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Tx-28PL1
Check Horizontal Output Transistor....if shorted,replace both
Horiz out transistor and flyback transformer...Use Panasonic
original parts, if possible.If transistor checks ok, then just replace flyback transformer ONLY.......................T.
Jan 25, 2008 | Panasonic TX-28CK1 28" TV
Television making chirping noise
Chirping or hissing from the TV is caused by a faulty CRT base socket in 95% of the cases. Replacing the base socket is an easy job, but care must be taken to get the same replacement base socket. You better desolder the existing base and take it to the shop to get one with the similar connections. Good luck.
Jan 22, 2008 | Televison & Video
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
Dec 02, 2007 | Samsung HC-P5241W 52" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic TX-28CK1 28" TV Logo
78 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
