Question about Panasonic DVD-LS90 Portable DVD Player
Code H03 hi , i am getting code h03 error. Please give me a solution.
  • 6 more comments
  • Anonymous Feb 06, 2008
    I'm getting the same code on my Panasonic DVD-LS90 with screen. I noticed the players is not reading the disk.
  • Anonymous Mar 19, 2008
    Same for me! Only used a dozen times....then this code. Machine will not read disk.
  • ashmha Jun 02, 2008
    CODE HO3
  • Anonymous Jun 08, 2008
    Same problem. Was working fine until last week and then it stopped.
  • Anonymous Jul 09, 2008
    error code h03 the same problem for me.
    please help me............
  • tundetot Aug 05, 2008
    WHEN I OPEN THE DVD AFTER THE REEDINGOF A DVD IS COMING CODE HO3,WHAT CAN I DO?THANKS
  • mitmay50 Oct 20, 2008
    my problem is the code HO3 please help me,thanks
  • rrdavis873 Feb 07, 2009
    Error code H03.
Error code h03
Posted on Jul 09, 2008
What does error H03 means af the Philips portable dvd PD9030?
Go to this link http://tech.rickumali.com/blog/2008/12/30/fixing-my-portable-dvds-h03-error
Aug 06, 2016 | Philips PD9030 9" LCD Portable DVD Player...
Error code H03.
To my knowledge Panasoni Error Code H03 indicates mechanical failure, more specifically, the traverse servo motor. Simply stated, the eye cradle could no longer slide back and forth along the slider bar. Corrective measure requires cleaning and application of appropriate light lubricant. Vaseline oil would do for the time bieng. Pls refer to the diagram below.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Panasonic DVD-LS850
Treadclimber TC20 giving error code H03 H13 H24 on starting
Dear Sir:
You must explain them, such as you did with the error, The PROM, EPROM, was corrupt, there are NOT anything we can do for fit it.
However if you wan to RUN the software calibration for diagnose, troubleshooting, do it.
sincerely. God bless you
May 08, 2012 | Bowflex TreadClimber TC20
My bowflex treadclimber tc 20 is putting out error codes H03,H13,H24 whats wrong
I have the exact problem. My machine is 3 days old. I am also getting this H03, H13, H24 error. I called the 1-800 number for the Treadclimber TC20 and they informed me that a handful of machines were sent out with a bad control board. I am waiting for a replacement board.
Apr 14, 2012 | Bowflex Treadclimber
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Error H03
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
Jan 06, 2006 | Panasonic DVD-LS55 Portable DVD Player...
Panasonic DVD-LS90 Portable DVD Player Logo
738 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
