D-link I just bought a new max range dlink router. I was originally on netgear. I have the router hooked to me desktop and am trying to get my laptop to go wireless with it. I have a dlink card in my laptop but it shows that it is not connected. I cannot get the laptop to find the wireless network. My laptop is a toshiba tecra 8200.
  • 145 Answers
Is the wireless enabled for your router? Try typing and use the default password to access your router settings. Check if wireless is enabled, SSID is broadcasted, and security is off or properly configured.
Posted on Feb 02, 2008
I just bought a laptop computer and I already had a desktop. My internet provider is Hugesnet Satelite. I bought a Netgear N600 wireless dual band router thinking I could just hook it up to my desktop...
The HN9000 should have an ethernet port. You will require two ethernet cables to connect the desktop to the router.
1. Connect the ethernet cable from the Modem to the Ethernet Input port on the Router (It is generally placed away from the other ports on the back of the router.) 2. Connect another ethernet cord from one of the output ports on the router to the desktop computer. 3. On the laptop, turn on your wireless card. The process for this differs from computer to computer. If you were to provide the model of laptop, I could provide you specific instructions. 4. The network setup should be complete.
If you need more help, let me know by replying to this solution. Thank you for using FixYa!
Apr 01, 2011 | NetGear Computers & Internet
Have a new desk top bought the wireless-g usb adapter wg111 to pick up my netgear range max wireless router wpn824v3. After installing the wireless-G picked up internet once but after the system was shut...
I have the WPN824v3 and it can be balky finding and connecting to a network sometimes. It works best (and gets the best range) using the Netgear RangeMax Wireless USB 2.0 adapter (WPN111). The router and this adapter are (according to Netgear) specifically designed to work with each other, thereby maximizing both the range and the speed of the router.
Feb 02, 2010 | NetGear RangeMax WPN824 Router
I am trying to setup a desktop (connected to
i have netgear fs 605 vs/fs608 v2 how to get connected with internet ?
Jan 28, 2010 | NetGear WGR614 Wireless Router
Netgear WG111 doesn't see D-Link DIR-655 wireless network
Hi Joe,
I would suggest you to change the wireless channel on the Dlink and use the channel on which WG111 will scan and connect to your network. Also, plese make sure to use the security encryption on the DLINK to WEP or WPA only. Using higher security like WPA2 will cause issues with this adapter.
Jun 21, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Router and New Print Server Not Talking?
what hardware version and firmware is on might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
I just bought a new computer but I want to stiil use my old one. How do I hook both up to my comcast cable conection?
you should have a router so that you can connect 2 or more can use linksys,netgear,dlink..
Jul 01, 2008 | Computers & Internet
Wireless access point connecting to router...
The question is how do you want to cable the netgear and what do you want to do with it.
If you cable a lan port of the DLink to the Netgear WAN port you will have two subnets that must be addressed differently. Opening up and forwarding the ports for XBox could be difficult.
I believe cabling the Netgear as an access point makes more sense. CONFIGURE THE NETGEAR BEFORE CABLING. This is achieved by wiring a lan port on the DLINK to a lan port on the netgear and ignoring the wan port on the netgear. This will involve configuring several router items that should be completed before the devices are cabled together. You will need to remember the Netgear's new network address and probably use a static IP address from a computer to configure it back into being a router after these changes, if required. Or reset the configuration to factory default following the users guide.
First the Netgear needs DHCP turned off as it will be part of the DLink's network and not a separate subnet - the DLink will perform the DHCP services.
Second the LAN side of the Netgear will need a static IP address in the DLink's network. This is where it may get tricky for you. Verify the DLink has an IP Address like and a subnet mask like That means all IP Addresses in your network start 192.168.0.??? where ??? is unique for your network. Verify your DLink router has a set of addresses reserved in the DHCP setup for dynamic address assignment these addresses like to If the above is true or with the information you extract from you DLink router you need to determine where you can create static IP addresses -- in the above case to are available. You need to assign one of those like to the LAN side of the NetGear Router. You will probably want to assign another to the XBox == like You will probably need to deal with opening ports or placing the XBox into the DMZ of the DLINK router which will require a static IP Address.
Now cable the devices
When considering the XBox Configuration below the DLink is the router that must be configured to allow the open ports or DMZ access to the Xbox == the netgear is not functioning as a router in this configuration.
Check out the following links on XBox Configuration if required.
The second link may be the best to start with.
The generic connection and configuration document
This is a good description of possible router2.gif options.
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 27, 2007 | NetGear MR314 (MR314NA) Wireless Router
Wireless connection
Try turning off encryption on the router. If you can connect after that it is an encryption problem.
Dec 25, 2007 | Computers & Internet
Can't see any wireless networks in the area, but I know there are many
Can your other laptop see the laptop with the problem. First check that it is being given an IP address in your router and set to obtain IP address automatically. You may need to give the wireless card an ip address and DNS address yourself within the same range as the others; this way you know the addresses are correct. Just check that your problem laptop has the same network group name, right click my computer>properties>computer name and check the workgroup name is tha same as rest of your pc's. Keep trying you'll win in the end!
Nov 17, 2006 | NetGear (IM-WG511T) Wireless Adapter
Open Questions:
Computers & Internet Logo
276 people viewed this question
David Payne
David Payne
