Question about Cuisinart Brew Central DCC-1200W, 12-Cup 12-Cup Coffee Maker
Cuisinart DCC1000 coffee maker
This is the second cuisinart coffee maker I've owned and I have the same problem with both. After awhile steam comes out of the top of the coffee maker leaving only about half a carafe of coffee. I have just about ruined a cabinet because of this. Am I doing something wrong?
  • 1 more comment
  • dbarber43 Jan 27, 2008
    I checked the reservoir and sure enough there is a hole, with no valve. I did turn the coffee maker upside down to rinse it out in case a coffee bean had stopped something up. Is it possible to order a new valve from Cuisinart, or is there another remedy to this particular problem
  • suebayb14 Sep 17, 2008
    I have the same porblem, but my model doesn't have an opening large enough to access the valve that has dislodged and I can't figure how to dissassemble the parts to fix it.
  • michellecoen Oct 24, 2008
    Yah my coffee maker is about 6 months old and the steam is evaporating about 2 cups worth of water out of every pot of coffee. I will check the valve.
    Scholar:
  • 142 Answers
At the bottom of the reservoir there is a hole the water flows through to the heater. When my coffeemaker did what yours does it was because a little valve that sits in that hole had popped out, and after tamping it back in it solved the problem. The valve is supposed to keep the hot water from going back up into the reservoir. Without it the water backs up, causing the steam to shoot up as you know, and heats up the water in the reservoir. This causes the thermostat to turn it off prematurely. The valve can come out of the hole either if the coffeemaker is turned upside down, or if there is a major buildup of mineral deposits that need to be flushed out -- they can overheat and cause too much back-pressure to the valve. Flush it with vinegar and push the valve back in as tight as you can, then be careful if you turn it upside down.
Posted on Jan 26, 2008
  • Alfred Reed Jan 28, 2008
    You could try Googling Cuisinart to see if they sell parts there. You might be able to scrounge one from another coffeemaker if you can get your hands on one, it is possible they are interchangeable since it is only a little plastic thing. Good luck.
Why doesn't the steam work?
Check if you are using it correctly. Select you model from manual
Espresso Makers Product Manuals Cuisinart com
If no hint, TAKE IT BACK WHERE YOU BOUGHT IT; STILL SHOULD BE ON WARRANTY
May 15, 2015 | Cuisinart Coffee Makers & Espresso...
Cuisinart Brew Master 00wpc brews slowly with most water escaping as steam
Try cleaning with white vinegar, using the method described in the owner's / instruction manual.
Jan 03, 2018 | Cuisinart Brew Central 12-cup Coffee Maker
My DCC1000 Cuisinart Coffee Maker shuts off.
Your unit needs to be repaired or replaced. Please call the manufacturer to determine your warranty status.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 22, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Since I cleaned our Cuisinart 12-cup Brew Central with "Dip-it"  destainer last week, it takes about 3 times longer to brew, and it steams outrageously practically the whole time.  Using the same...
Run 1/3 caraffe vinegar and 2/3 caraffe water through the machine.
Dip-It is not the best cleaner to use with this coffeemaker - stick to distilled white vinegar.
If the cleaning fails to resolve the issue, and the unit was purchased in the last 3 years, call Cuisinart and see if you are still in-warranty.
Mar 14, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Feb 22, 2009 | Cuisinart EM-200 Espresso Machine
Cuisinart automatic grind and brew
Clean it out with vinegar and water - 2 ozs distilled white vinegar, 2ozs water
Dec 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffee maker: no power coming into unit. When I took the bottom off to look at the circuit board I shorted the circuits and saw that there is power coming into the board, but it isn't getting...
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Sep 28, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Dec 26, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Brew Central  DCC-1200W, 12-Cup 12-Cup Coffee Maker Logo
358 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
