Question about Sony Playstation 3 (PS3) Console
Playstation froze; will not play PS3 games or PS1 games
While playing my 80gb playstation 3, with Ratchet and Clank Future Tools Of Destruction, a Playstation 3 game, the playstation 3 system froze. I could tell that the system froze because when I pressed the ps button on the wireless controller, the system menu would not come up. After that I turned off the system and turned it back on as described in the troubleshooting section of the manuel. The system will NOT play ANY Playstation 1 or Playstation 3 games; it will only play Playstation 2 games. I have already unplugged and plugged back in the system. I have also pressed in system settings "restore default settings" and "restore PS3 system". I did a complete reformat. It still will not read any PS3 or PS1 games. It will play DVDS. Please help me.
  • izzyman13 Jan 26, 2008
    I just tried playing a blue-ray disk movie, but that did not work either.
    Scholar:
  • 64 Answers
Sounds like a program error in your software/firmware, or possibly a bad laser (disc reader). I have the same problem from time to time but it's fine after I reboot. If you have already restored to default and did the updates and still have problems I would return it for a new one. Just make sure that you have loaded the latest updates (2.1 or 2.2) I think, before returning it. If the store won't take it back due to some restricyions in their return policies I would suggest contacting Sony and shipping it off for a replacement. Your Sony warranty should cover it but you might have to pay for shipping costs.
Posted on Jan 26, 2008
  • 4,102 Answers
Hi this is a huge problem with ps3 it can be one of two problems the first is the expensive one this is over heating if the ps3 has been used on carpet or placed on top of something like dvd player or video or cable or sky box this causes the ps3 to overheat and the damage is usually to expensive to repiar the other problem alot of people are having is with the fan blowing dust onto the laser lense and this causes the ps3 two stop laying certain games if your warrant has run out you could remove the case and clean the lense but dont use any kind of liquid only use dry cloth but a soft one do it gently.
I dont avise doing this if your ps2 still has warranty left as this fault is covered by warranty and they will replace your ps3.
Im going out for couple of hours now so if you need further assistance let me know ok
  • paul proctor Jan 28, 2008
    hi you could try tilting your ps3 into different positions as this sometimes moves the laser slightly letting it work also try standard dvd as this is the easiest format for the ps3 to read try it tilting ps3 sidewards and at 45 degree angle hold it in position and see if game loads can even try upside down as the disk will still be located in right place failing this then you will find that either the laser needs realigning or even replacing.
    Theres only a few places you can buy new laser from and they are easy to fit but the problem you will have is realigning the laser as you will need osciliscope to do it with and these are expensive to buy so not worth it would cost more than new ps3.
    If you have warranty left send it back and they will give you new one or if your warranty has run out then the cheapest solution is to take it in to get repaired as buying the laser and equipment to align it with would be more than buying new ps3.
    But first try your ps3 at different angles on its side upside down keep trying and if it works just remember what angle it worked at failing this you could buy a good lense cleaner in form of cd to clean the lense if this still dont work then you need to get the laser replaced. let me know if you need further assistance
    The reason it plays ps2 games and dvd is because the laser isnt working as hard to read the data on the disk the hardest data to read is blue backed disks as the laser has to adjust to read the data usually when you realign a laser you start by using dvds or ps2 black backed disks you get these working ie loading then put blue ray film in then align so it reads the disk then put ps3 game in like a top game that would be difficult to read then you align it up to work with this type of disk then you should have no problem playing all formats but as your only plays certain formats then that suggests that the laser could be on the way out or could even be that the ps3 has overheatd and damaged part of the board that converts the data on disk to playing format this can cause problems loading games and with the unit freezing during gameplay
6ya staff
SOURCE:
I purchased my ratchet and clank tools of destruction and my new slim ps3 from amazon recently. The game skips sometimes during videos and goes out of sync and even froze once! i've no other games to...
XBOX 360 lets you install games to the hard drive to make for easier loading to put less stress on the system by saving the PS3 does the same thing, however they dont let you install every game just exclusive titles, so I would try that before assuming it's your system.
Aug 31, 2011 | Sony Ratchet & Clank Future: Tools of...
I have ps3 played 30minuts and he is freeeeeeeeeeeeeeeez i return  to the shop and got anther own i played 5days and the ps3 freez when play mtg4 i got the ps3 and going to shop very angrey the...
Try swapping games? When I first bought my PS3 I found that Uncharted Drake's Fortune froze often and had problems through the whole game, all other games worked fine. May just be a bad update or a problem with the game
Mar 24, 2010 | Sony Ratchet & Clank Future: Tools of...
Need 419 mb space wen i brought console new
Maybe it wasn't brand new after all.
You can clear up the old user data by deleting it from the GAME menu. Check Game Data Folder.
If there are games that you've never played before or games that you aren't going to play anymore go ahead and delete the files.
Best of luck!
Jun 19, 2009 | Sony Ratchet & Clank Future: Tools of...
I also have that problem
For those of us eager to get some platforming action joy with Insomniac Games' latest next-gen masterpiece on the Sony PlayStation 3, Ratchet & Clank Future: Tools of Destruction, you may have encountered a glitch that stops the fun dead in its tracks. Thankfully, a workaround has been provided by none other than Insomniac Games itself through the company's own community manager James Stevenson.
So what causes the video gaming happy to suddenly cease and desist? James Stevenson explains that like Resistance: Fall of Man, Ratchet & Clank Future: Tools of Destruction needs to install a few files into your hard drive for the game to actually run. Here's where things start getting a little dicey: even though you've got loads of free space on your hard drive, the game could read your hard drive as full, and therefore refuse to install. Ouch.
What's the workaround, then? It's really a simple procedure. James advises that to make the problem go away, all players need to do is either free up 500 megabytes' worth of space, or download 500 megabytes worth of data from the PlayStation Network Store. Yes, we know, it's weird, having to fill up your hard drive just so a game can detect all the loads of free space available, but if it lets us play something as good as Ratchet & Clank Future: Tools of Destruction, then fill up we must.
Jun 09, 2009 | Sony Ratchet & Clank Future: Tools of...
How do i play this ratchet and clank game
BUY IT or DOWNLOAD it from PLAYSTATION STORE on ur PS3
Jan 18, 2009 | Sony Ratchet & Clank Future: Tools of...
Brand new PS3 says not enough memory to play game
If this is a PS2 game that you are playing on the PS3 you need to set up a internal seperate memory card for that game and that will fix your problem how to set up a internal memory card goto the icon that says game scroll up till you see memory card utility click it then click new internal memory card.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
I can't play ratchet and clank!!! It says not enough space but...
if you have downloaded somedemos or pics that takes some mb
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Ratchet clank tools of destruction will not load
If the PS3 is brand new, then I had this same problem yesterday also. Download a 1 or 2 free demos and INSTALL them by selecting them after the download. Then delete the games. I tried this from the Sony PS3 Solutions page and it worked. There are other solutions in their solutions database. Good luck and happy gaming.
Dec 25, 2008 | Sony Ratchet & Clank Future: Tools of...
Ratchet and clank future: tools of destruction game doesnt play
I have read through some forums for you, and it appears that there is a bug that reads your disk as full even if it is not. The fix is to add at least 500MB of game data to your harddrive, then it will work. I think the bug was on the american version of the game. It read an almost empty harddrive as full.
I hope this helps
Nov 27, 2008 | Sony Ratchet & Clank Future: Tools of...
Sony Playstation 3 (PS3) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
