Question about Saeco Royal Professional Espresso Machine
After a move, the pump at rear makes constant noise (like pump is leaking) and ventilate is showing on screen
The constant hiss coming from the left rear, even as the unit warms up and gets to ready. ventilate is showing on the screen.
how do i dismantle the unit to check the pump connections? (as i suspect that is what is needed)
I want to make sure i take it apart in the right order
thanks
Simon
  • simonmac2 Jun 20, 2008
    i sent it away yesterday...couldn't find the problem.
  • 40 Answers
Contact Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 20, 2008
Ventilate message, then no steam coming out
Sounds like you have an internal blockage in one of the boilers.
Take it to your local service agent for repair.
Did you remove the milk frother and try the hot water again?
A blocked frother is a very common problem .
Feb 24, 2010 | Gaggia Titanium Espresso Machine
Hissing sound coming from speakers
I found out that if I manually turn the speakers down on the tv and then turn it up with the remote control the hissing sound goes away
Mar 18, 2009 | Toshiba 65HDX82 65" Rear Projection...
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
Green Cloud show close to mid lower left center on most black screen
you will need the optical unit cleaned, if that does not resolve then the optic unit needs replacing
Jun 18, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Hissing sound and constantly running generator
The only thing I can think of that you may be hearing would be if the compressor has a problem. If you notice cooling performance decrease or it stops cooling, I believe you will find the compressor has bad internal valves. It will probably take a technician to properly diagnose this and if the compressor has this problem the only answer is to replace the compressor.
I hope this helps, supertechks
Mar 28, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Tv won't stay on!
Check C506 = high failure item # 483512247584 680pf / 2kv
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
NEC P1250+ hisses and scrren blips intermittently
I had the same problem. Your monitor is warning you of failure. The hissing sound is the picture tube powering up. The momentary blank screen is when the power supply for the monitor has become hot. Your monitor is getting ready to quit. My suggestion is to buy a new monitor. To have a tech repair it would be more expensive then buying a new one.
Sep 19, 2007 | NEC MultiSync P1250 Plus (White) 21" CRT...
Saeco Royal Professional Espresso Machine Logo
184 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
