Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony KDF-42WE655 Replacement Lamp
I replaced my lamp on my KDF-42WE655 LCD Projection TV with a Phillips PHI/A1606-034B (XL-2100U). After installing the new lamp I smell a burning smell. I have not noticed any problem with picture quality but am concerned about the burning smell. Please advise
  • Brian Vibberts Oct 11, 2012
    I just replaced the same lamp in the same exact Sony TV and I smell the same smell.
  • Anonymous Apr 01, 2014
    I am experiencing a blue halo in the background of the picture. I just replaced lamp and housing with a new oem phillips xl 2400 lamp hoping it would eleminate issue. No such luck. Any suggestions.
    Thank you.
    President:
  • 4,402 Answers
First thing i would ask is where is the smell coming from?
Posted on Jan 31, 2008
I need LAMP DOOR Cover Mine got warpped from heat
Contact someone from sony, call or send them an email asking where you could purchase this replacement panel.
Jan 27, 2015 | Sony Replacement lamp for Grand WEGA or...
Where is the lamp module located for a sony kdf 42we655?
Please read here: http://esupport.sony.com/US/perl/news-item.pl?mdl=KDF42WE655&news_id=84
From SONY:
If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it is time to replace the lamp with a new one (not supplied).
Use only a replacement Sony XL-2100U or XL-2100 for your TV. Use of any other lamp may damage your LCD projection TV. Contact your Sony dealer for a replacement lamp.
Click here to download step-by-step directions for replacing your TV's lamp.
Note: Before replacing the lamp, turn the power off on the main unit. Wait several minutes, then unplug the power cord. (The cooling fan will continue to blow for about two minutes after turning the power off.)
Be sure to allow the lamp to cool down completely before removing it. The surface of the lamp remains extremely hot for at least 30 minutes after the power has been turned off.
Mar 10, 2011 | Sony KDF-42WE655 Television
It overheats and pops the Xl-2100u lamp?
by pops? do you mean it explode? how many lamps? it could be the fan that supposed to be ventilating the lamp or it could be the the ballast, why the ballast because the ballast regulates the voltage in order the keep the lamp on, for ignition it sends around 15,000 volts after that it regulates the votage to a small amount of voltage around 5,000 so it could be sending the big amount of voltage all the time never regulates that or it could be regulating and then sending another big amount of voltage over and over until the lamp doesnt handle those changes.
Apr 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a sony wega 46 inch tv model number: KDF42WE655 the screen went black and the red light came on where it says "lamp" on front of tv Does this mean I just need to replace the lamp?
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.But pretty much it does sound like the lamp.your part # will be xl-2100 and you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm and here's the instructions to replace it: http://guides.fixyourdlp.com/sony/XL-2100U.php Have a blessed one!
Feb 10, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i install a replacement xl 2400 lamp within a housing unit into my sony wega kdf46e2000 tv??????
how do I REPLACE THE LAMP IN THE kdf-42WE-655 WEGA TV. i PURCHASED THE REPLACEMENT LAMP, PART NO. XL-2100U>
Sep 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Need instructions on removal of the original lamp and housing and subsequent replacement with a new one on my Sony 42-inch LCD TV Model No. KDF-42WE655.
Hello! Here you have a picture guide and alos a video of how to replace the lamp, just go to http://guides.fixyourdlp.com/sony/XL-2100U.php good luck!
Jul 14, 2009 | Sony Televison & Video
Sony xl-2100u lamp
Refer to your owners manual on lamp replacement. Remove the old lamp and look at it. If it looks "blown" (like a flashbulb) then it is defenitely defective.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 2004 Sony LCD projection TV. The set
It is symptom of weak Lamp (bulb) that requires replacement.
You can buy Sony original lamp from Sony Accessories Store.
Lamp required for KDF-42WE655 part number is as follows..
A1606034B LAMP BLOCK XL-2100U
May 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Grand WEGA KDF-70XBR950 70 in
You need a new projection lamp.......(XL-2100 replacement DLP lamp)..... go to this web site to get the lamp you need for your TV model KDF-70XBR950 70inch----
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040980
------ This web site shows you how to install it yourself. ----
http://guides.fixyourdlp.com/sony/XL-2100U.php    --------- I strongly suggest that you get a SONY manufactured replacement lamp NOT a cheaper lamp from another manufacturer... it costs about $200.
Adelaide B.
Oct 30, 2008 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Help for Sony XL-2100U Projector lamp
If you need XL-2100U Lamp for your Sony Grand Wega, its available on Sony Accessories and its price is approx $200
Here is bit details of required part from Sony web site...
Part Number is ... A1606034B LAMP BLOCK XL-2100U
Compatible Models
  • KDF-42WE655
  • KDF-50WE655
  • KDF-60XBR950
  • KDF-70XBR950
  • KF-42WE610
  • KF-50WE610
  • KF-60WE610
  • Need further help, let me know.
    Sep 20, 2008 | Sony XL-2100U Projector Lamp for...
    Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
    1,402 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
