Question about Packard Bell iWork 9427 (P721001702) PC Desktop
Alarm when i turn my computer on there is this bleepin alarm coming from the tower can you please tellme whatthis is and how to solve it please thankyou
  • 1 more comment
  • XxlovelyxX Jan 26, 2008
    it beeps loads all the time for about 10mins my screen works normall but the beeps are coming from my tower it self
  • crunchie_7 Feb 01, 2009
    I have the same problem. My tower makes a series of three beeps repeatedly and refuses to turn on, the fans power up, the beeping starts, the moniet reveals nothing but a blank screen. How can this be fixed?
    I've tried disconecting my cables but there has been no change
    Katherine
  • Anonymous May 11, 2010
    How many beeps are ther coming out of your computer? and what is the name of your BIOS
    Scholar:
  • 131 Answers
Hi it could be the RAM is loose to fix this open tower discharge static by touching frame of computer...push down on stick of RAM untill the white clips on either end close fully and lock on either end of ram you will probably hear it clicking or else if your windows icons come up it could be the disc drive has a loose connection push in the power supply and the connection to the drive known as IDE cable ( wide ribbon) or SATA (slim connection) and make sure the end of the IDE or SATA connection which ever connection it has is pushed into motherboard fully ....hope this was of some help best of luck
Posted on Nov 05, 2009
Depending on how many bleeps you hear..indicates a problem..or a key could be stuck on your keyboard..ctrl alt and delete is only to shut down or restart your pc..and the brains of your pc is not your tower but your processor...if your pc is running normal after start up then the problem is small. if your still having this problem let me know how many bleeps you hear or if its a contuinuios bleeping it sounds like a doggie keyboard..
Posted on Sep 24, 2008
Beeps usually indicate something is not plugged in or a program is not running properly for 'whatever' reason...r there any errors on your screen? If not, does it continue to beep after window icons have loaded? If so, try typing ctrl/alt/delete (at same time) to see if an apllication continues to run b4 it shuts down... If so, note that program application file, as you may need to delete that program and reload it to solve your 'beep'. Had a similar problem with my Canon fax/scanner/printer...Hope this helps.....DayGirl48
Posted on Jan 26, 2008
  • Anonymous Jan 26, 2008
    your tower is the 'brains' of your computer...your monitor is only an output device. What do you have connected to your tower in regards to cables in the back? You can begin to troubleshoot this yourself by removing the cables one at a time and restarting your computer to determine the culprit if you are not getting any errrors on your screen. Remove all cables except your monitor, and mouse(unless its wireless)...and restart your computer...make sure your harddrive completely stops spinning between restarts to avoid damage to the harddrive (about 1 minute or so is good-depends on how much info on the drive)...if it still beeps, you've got an internal program thats malfunctioning....did you try the ...ctrl/at/del?...what did it tell you??....good luck....darla
6ya staff
SOURCE:
My tower turns on and makes this consistent beeping sound. And nothing shows on the screen.
I believe from my own past that the beeping sound is an over-heating alarm, and that you need to get more fans installed inside. Try taking off the door to your tower, and point a fan in on it and turn off the computer, wait about 5 minutes with the fan set to high to see if that solves your problem. If it doesn't then I suggest you take it in to the shop or wait for some more possible answers on here.
Hope this helps!
Remember to give me 4 Thumbs Up for Helping out the Community :)
~~Dayminner
Jun 03, 2011 | Computers & Internet
Mobo on my rosewill armor mid tower wont function. have repalced mother noard an gpu I do not know what to do it turns on fans spin but no mobo activity
Make sure that your power connectors into the motherboard are all firmly connected. I had the same problem, the solution was that the CPU , 4pin molex connector was disconnected.This connector may initially be 6 or 8 pins but the 4 can be separated from the others. This should solve your issues.
Feb 18, 2011 | Rosewill ARMOR Gaming ATX Mid Tower...
I have hp dc7100sff desktop computer the prolem is that when i turn computer on the computer show me red light and give beep continous & not giving display...plz help me to solve this problem
please open the tower of the computer from the side and clean the RAM of the computer using a soft cloth and make sure no dust is present .Put the stick in the same way back and close the tower .
The problem should be resolved
Nov 11, 2010 | HP Compaq dc7100 PC Desktop
Pl tellme product key number
XCKFY-RCW4V-B2C2B-QWXP7-P9MYJ
or
HJJDB-PBJX8-4WY4M-3HC9M-W8BYJ
plz rating
thankyou
Sep 17, 2010 | Microsoft Office Professional 2007 Full...
Alarm on
the mechnism that raises the paper for feeding may be faulty, call in a technician
Sep 10, 2009 | Panasonic Workio DP-2500E Copier
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Raidmax Sirius mid-tower case fan alarm
Here are some solutions:
1. Try to use some silicon oil in fan apertures to decrease rub
2. Try to manually (look for a mainboard's service software settings) decrease rotation speed if available
3. Less recomended: disconnect fan cable from mainboard and don't stress your computer (try not to overheat, - work with software that uses less resources) and buy a new one when available
Jan 28, 2009 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Alarm
It sounds like maybe a stuck key on the keyboard, Check that out first and see if there is one hung up on a piece of paper, crumbs , ect. check the keys and I think that should solve your problem, If not you can write back here again and I will try something else. Thanks
Jan 26, 2008 | Packard Bell Easy One Silver 2101 Notebook
Open Questions:
See all Packard Bell iWork 9427 (P721001702) PC Desktop Questions
Packard Bell iWork 9427 (P721001702) PC Desktop Logo
522 people viewed this question
Top Packard Bell Computers & Internet Experts
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
