Question about Packard Bell Easy One Silver 2101 Notebook
Alarm when i turn my computer on i get this sort of bleeping alarm from the tower its takes about 5mins to half hour to go off. can you please tell me what this is and how to solve it please. thankyou
  • 3 more comments
  • XxlovelyxX Jan 26, 2008
    no the screen works normall the beeps are coming from the tower it self
    its not the keys the beeps are coming from the tower every thing works normal the beeps are coming from the tower
    no stuck keys i unpluged the key board n turned comp back on but doin the same
    i have un pluged every thing even the monitor n still alarm goin off i cant see what it can be please help as frustratin listing to it when i turn my computer on thankyou
  • Salehe Kungule
    Salehe Kungule May 11, 2010
    is there anything displays on the desktop when the system beeps?
    Sergeant:
  • 239 Answers
It sounds like maybe a stuck key on the keyboard, Check that out first and see if there is one hung up on a piece of paper, crumbs , ect. check the keys and I think that should solve your problem, If not you can write back here again and I will try something else. Thanks
Posted on Jan 26, 2008
  • 2 more comments
  • bear001 Jan 26, 2008
    That is where the beeps would come from if you had a key stuck. I take it that you tried and there was no stuck keys.
    I am wondering what type of error is it reading when you first start computer.
    Check you memory and make sure that it states the amount of Ram you have is what your using.
    Because It may have had a module come loose too.
    Can you hear you fan turning on, You also tried another keyboard and mouse see if the beeping goes away,
    There is something Not right you already no, But I may need more info. Can you do a system restore to a day or two before this happened. I am pretty sure its not that and some hardware failure. Be it memory, keyboard,Mouse, or some other hardware..
    Hey I have to run out for awhile so I won't be back till later but If you need help write back and I will get back to you., Thanks
  • bear001 Jan 27, 2008
    do u know how to get into your bios, If so you can go into there and shut off the alarm and the security settings in you bios, I just don't understand why your computer is beeping, and it still works with no error messages on your screen, You should be able to disable it in your bios, I see you still have access to internet and are on the computer your talking about right ? Well do a F2 on start up and follow directions and shut off warning alarm It shouldn't affect your system if it still works, Hope that gets the beeping gone for you.
15 year old micromark intruder alarm need to switch off
Not really enough info to give you an answer, but I can generalise...
You say Knocked alarm box with ladder alarm started"
If the fault is there permanently from when this happened there's a good chance that you have disturbed the tamper spring/switch on the cover of the alarm unit. when the front of the panel is removed you should be able to see the Sping/switch which is automatically depressed by this front panel, you may find the spring has fallen off the switch or gone out of alignment, refitting / realigning it should remove the tamper fault once the lid has been refitted properly. As for "bleeps when doors, windows opened"
This sounds like the "Chime" feature has been switched on and without the manual I cannot tell you for sure how to switch it off.
Chime is a feature which "Chimes" when a door is opened (Not often used on windows), if this started when the ladder fell on the panel it is most likely just a single key press to switch it off, Once the tamper fault is sorted you should be easily able to find the correct key press to turn the chime feature off.
Sorry for being a bit general but I don't have that particular manual. Hope the info helps you :o)
Mar 20, 2017 | Home Security
My desk top pc wont boot up im getting the first screen and the bleeps but then nothing what can i do
If you are receiving continuous beeps, it means that computer is not recognising the RAM (memory). In this you have to open the Tower and follow the below steps:
1. Turn OFF the computer
2. Open the flap of the Tower (Remove the screws from the back of Tower)
3. Now, On the Motherboard you will be able to see the RAM see the picture nanjia.jpeg
4. There should be two pins to unlock and remove it
5. Once removed, clean the terminal and replug it.
6. Turn ON the computer, it should take care of the issue
Thanks and regards,
Nov 22, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
Bleeping
Do you have your camera set for continuous focus tracking?
Feb 26, 2010 | Canon PowerShot Pro1 Digital Camera
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Raidmax Sirius mid-tower case fan alarm
Here are some solutions:
1. Try to use some silicon oil in fan apertures to decrease rub
2. Try to manually (look for a mainboard's service software settings) decrease rotation speed if available
3. Less recomended: disconnect fan cable from mainboard and don't stress your computer (try not to overheat, - work with software that uses less resources) and buy a new one when available
Jan 28, 2009 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
nikunj@qool-point.co.kr
Nov 17, 2008 | Liebherr Refrigerators
Alarm
Beeps usually indicate something is not plugged in or a program is not running properly for 'whatever' reason...r there any errors on your screen? If not, does it continue to beep after window icons have loaded? If so, try typing ctrl/alt/delete (at same time) to see if an apllication continues to run b4 it shuts down... If so, note that program application file, as you may need to delete that program and reload it to solve your 'beep'. Had a similar problem with my Canon fax/scanner/printer...Hope this helps.....DayGirl48
Jan 26, 2008 | Packard Bell iWork 9427 (P721001702) PC...
Machine emits continuous high pitched bleep and power light flashes blue/red
If working OK, probably means that the temperature alarm goes off because is getting hot the PC. I suggest to check why is that happening. All fans working OK? is the CMOS temperature alarm set too low? check your motherboard instructions booklet- It will tell you what the beeps mean probably in the last pages. Good luck
Sep 28, 2007 | Sony VAIO PCV-RX511 PC Desktop
Packard Bell Easy One Silver 2101 Notebook Logo
61 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
