Washing cycle zannusi aqua cycle 1400 just stops half way through, but works at other times
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 26, 2008
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy...
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Jan 30, 2010 | Indesit W 123 Front Load Washer
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Aqua stop activated
A simple problem can disable a washing machine: if water runs back into a washing machine from the drainage hose, then the aqua-stop engages. This can happen due to a defective water pump.
In this case it could help to tilt the washing machine so that the water drains and the aqua-stop is deactivated. (Of course you’ll have to fix the cause of the problem beforehand).
Thank you for contacting Fixya.com
Aug 06, 2009 | Bosch Washing Machines
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Oct 19, 2008 | Siemens WXLP1460 Front Load
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
