Question about Canon PIXMA MP160 All-In-One Printer
Problem I have a 160 all in one , it says paper jam or E 3 in flashing screen but there is no paper jam please help, many thanks Dr. Sahar univ. of Baghdad lIraq
  • 1 more comment
  • umyounisahar Jan 26, 2008
    I m
    Im waiting for an answer
  • umyounisahar Jan 31, 2008
    I tried that but it didnt work
    Ithink I have to take it some office to fix it
    thanks for your concern
    Scholar:
  • 35 Answers
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
Regards
Malik Khan
Posted on Jan 27, 2008
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 16, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
6A00 error code?
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 16, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Flashing paper jam after I unjamed.
Please perform he steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=uk&lc=en&dlc=en&product=441125
Now perform the following steps:
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
If the issue persists, please repair your printer as this is a hardware damage.
:) Dr Tony
Apr 15, 2010 | HP Officejet 5610 All-In-One InkJet...
The "check paper and check cartridge" light flashes and "Copies" says "E"
Check Paper/Check Print Cartridge Indicates the need to:
* Load paper
* Remove a paper jam
* Reinsert the print cartridge
* Replace the print cartridge
* Close the print carriage access door
Please perform the steps provided in the following web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00476294&cc=uk&lc=en&dlc=en&product=428800
:) Dr Tony
Apr 15, 2010 | HP PSC 1510 All-In-One InkJet Printer
I had to clear a paper jam in my Artisan 800 printer. i followed the instructions and cleared the paper, but when i turned the printer on the the screen continued to flash and indicate error. the paper has...
This problem is usually caused by the CR Scale forced out of it's **** by a paper jam. The CR scale is a 1/4" wide strip of grey plastic band that is visible when you open the printer. It is right above the serial number. Slide the head carrier to the left and look behind the head carrier. You will see a small U-shaped plastic piece. Make sure the CR scale is within the **** or u shape. Be very careful not to damage the CR scale as you slip it back it. When this scale is flipped out of the ****, the printer head slams into the right side of the printer on start up (twice) and produces the fatal error message, with the paper jam note.
Mar 24, 2010 | Epson Artisan 800 All-In-One InkJet...
I have an epson stylus photo 1400, and i did somethign stupid and jammed some paper, and i would like to know how to remove it. i can see it, but i can't grab it, and i don't know if there's any way i can...
Well first of all you can try to reset your printer -
Turn off printer
Press and hold 'stop' 'maintenance' and 'power'
buttons for about 10 seconds.
A message will appear on the screen.
power off and back on for reset.
Try the following steps to clear any jam -
1. Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
2. To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
3. For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
4. Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
5. Try printing another document.
Good Luck!!
Thanks
Oct 06, 2009 | Office Equipment & Supplies
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
What do I do if there is no visable paper jam on the printer Canon MP 160 printer
The flashing code may be a sign that your printer needs servicing, it's most likely the mechanism that feeds the paper. If you tell me what printer it is maybe I can help you interpret the code.
Hope this helps
Dec 28, 2007 | Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One Printer Logo
244 people viewed this question
old marine
old marine
