BIOS Upgrade I have a Mesh PC fitted with an ASUS ATX Micro NForce 4 939 PCI motherboard. I have just replaced my AMD Athlon 3500 chip with an AMD Athlon X2 4200, which runs fine. However I have heard that one can get a BIOS update that will make the most of the new chip. Is this correct and if so, where can I get it and what is it called?
  • 319 Answers
Please read the following statement from ASUS:
All BIOS posted at ASUS Website is for products sold and packaged by ASUS. BIOS for products sold and packaged in other vendors systems should be downloaded from web sites indicated on their product information / support guide. Updating the BIOS only if you have problems and you are sure that the new BIOS revision will solve your problems.
Careless updating may result to more problems with the motherboard!
I suggest that you contact MESH Computers for specific updates!
Brian
Posted on Jan 26, 2008
    Guru:
  • 1,894 Answers
Bios update will be avilable in the site of your motherboard itself
  • 2 more comments
  • dewan nafees ahmed Jan 26, 2008
    i would like to notify you something. since you have installed the new chip recently you wont need a bios update so soon. bios updates are released at a lond periods of time.
    mostly the update you are downloading wil have been installed in your PC already.
    A couple of big pictures of the Athlon 64 X2 4200+ AMD says the Athlon 64 X2 should fit into existing motherboards with only a BIOS update, provided that the motherboard can deliver enough power to drive a current 90nm Athlon 64 processor. Existing Socket 939 CPU heat sink/fan combos should be sufficient to cool an X2, as well. As always, you'll want to check with your motherboard maker before assuming your mobo will work with the new chip. There are always exceptions.
    yours seems to be working fine right. so no problem
  • dewan nafees ahmed Jan 27, 2008
    many thanks means>? problem solved or not?
6ya staff
SOURCE:
My husband recently built a new computer (previously built 5 others successfully). Motherboard seems to be working properly. Green LED lit. Graphics card works in another computer. Power supply...
Hi, the thing to do here is to narrow down what could be causing the problem, initial suspects would be the RAM chips. If you have known working ones you can try in it, try these, if not, try without one, then swap them over, or even try without both.
Also, remove any components that aren't strictly necessary, i.e. hard drives & cables, cd-rom/dvd drives, extra PCI cards,network cards etc
Another suspect may be just a loose connection, try taking everything out, re-seating it. Again, pay particular attention to the RAM chips.
It could possibly even be a faulty processor, have you another you could try? Try taking it out and re-seating it.
Apr 12, 2011 | ASUS M4N75TD AM3 NVIDIA nForce 750a SLI...
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
Motherboard replacement
ok it goes with size of board and there will be screw holes under the motherboard and spacers on the holes for yours if it will only fit a micro then youll need to get a micro board if the case has room then you can get a normall size board my advice here tho is to replace the board and the cpu i would get a 775 motherboard with pci e and ddr 2 you can get one from ebay for 35 pounds new and 10 pounds used and you will get a pentum d 820 used for about 10 to 15 pounds its a cheep way to upgrade as this is in my op the best boards around and the cheepist best cpus (you can alsow get micro boards 775 socket like the bio star board ) hope this info is of some use to you
Mar 18, 2010 | Pine Technology XFX MIA78S8209 GeForce...
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
Motherboards
This board should have everything you want and be ready for a 45nm architecture when you decide to upgrade your processor.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4399367&CatId=2874
May 19, 2009 | Computers & Internet
How to upgrade processor on ASUS A7A266 motherboard?
looking at this old motherboard the 2400 is unlikely to work, the motherboard has a cpu fsb support of 133mhz and supports the duron processors.
offhand, 2400 wont work.
Mar 18, 2009 | Computers & Internet
IS MCP61S THE SAME AS NF61S MICRO 754
Biostar offers NF61S MICRO 754 Motherboard + AMD Mobile Athlon 3200+ (COMBO56), NF61S MICRO 754 Motherboard + AMD Mobile Sempron 3300+ (COMBO56A),NF61S MICRO
Motherboard Processor:
Socket 754
Supports AMD Athlon 64/Sempron Processor
Support AMD HyperTransport up to 1.6G
Supports AMD Cool'nQuiet Technology
• Chipset:
NVIDIA MCP61S(GeForce 6100/nForce 405)
they are the same motherboard .hope this helps pls appreciate by rating it as fixyaa
Oct 10, 2008 | Computers & Internet
MPN: A7S333
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
BIOS Type: Award
amd 3200 + anthlon ok with fsb 266 mhz soket a
Open Questions:
Computers & Internet Logo
136 people viewed this question
Ekse
Marvin
Marvin
