Question about Frigidaire GLEB27S7A Electric Single Oven
My oven is beeping!
The display shows F1 and the oven is beeping. The manual says to hit the cancel button and reprogram it. None of the buttons are responsive so hitting cancel does nothing. It also says to reprogram it. Not sure how to do that. I don't know how to shut the power off to the oven except from the main circuit breaker. Any solutions?
  • tperreira Jan 28, 2008
    My oven is hard wired on it's own circuit so no off switch. Did exactly as you suggested and stopped the beeping. Apparently there really is some kind of fault because the control panel buttons are still not completely functioning, but it was more important to get the beeping stopped! Thank you!
  • CREVEY Mar 11, 2008
    MYOVEN HAS A F1 FAULT IT IS A 2003 MODELCFEF357CS2 AND I DO NOT KNOW HOW TO REPROGRAM THE OVEN
    Scholar:
  • 79 Answers
Try turning it off at the mains, then whilst turning it on, press and hold the cancel button.
Check the fuse and any other electrics on the same ring; eg. Washing Machine - this can indicate that the circuit breaker has tripped, replace any fuses and check integrity of electric on that circut, then flick it back on.
Posted on Jan 28, 2008
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
Oven is beeping and showing f1
Hello Charlie,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
GENE
Nov 06, 2011 | Neff B1421 Electric Single Oven
My top oven shows F1 and keeps beeping what is wrong?
Aug 18, 2011 | Frigidaire PLEB30T8A Electric Double Oven
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
My whirlpool range model#rf114px513 started
You will need to press the stop /cancel button this will clear the display
Nov 15, 2009 | Ovens
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
Control beeps continuously. Display shows F1. Started when oven had not been used for a long time. Pushing oven and timer off buttons resulted in 10 seconds of silence before beeping resumed. Same for...
Usually, This means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 28, 2009 | GE Ovens
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire GLEB27S7A Electric Single Oven Logo
641 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
