Question about ASUS Intel 850 Chipset P4T-E (P4T-E/WOA) Motherboard
4 seconds long beep
I hav a problem with my asus mboard. it does not start at all.. my videocard are okey my processor are okey & my memory are okey... can u help me? its an ASUS P4t Mboard
  • Leydi Apr 21, 2008
    Mi computador no enciende y creo que es la configuración del chip, quisera saber como es la configuracion correcta
    Gracias
  • nash250 Jan 19, 2009
    Hi, My machine also just beeps when i start it up. I have checked the RAm, CPU, Hard drive connections and the power supply. Could it be the motherboard??? please help!!!
Goood
Posted on Nov 01, 2008
    Scholar:
  • 58 Answers
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Posted on Jan 26, 2008
    Novelist:
  • 113 Answers
Are you sure that it only the one long beep? Usually there are additional short beeps after the long one, unless it is the DRAM problem listed here:
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
AMI BIOS:
none power supply, motherboard, or PC speaker is no good.
1 short system RAM Refresh failure.
2 short memory error
3 short same as 2 beeps; follow diagnosis above.
4 short system timer error
5 short cpu Failure. Replace the CPU or possibly the motherboard.
6 short keyboard error
7 short cpu or motherboard error
8 short video card error
9 short rom checksum error
10 short cmos error
11 short cache memory error
1 long, 3 short memory test failure.
1 long, 8 short Display test failure
6ya staff
SOURCE:
I am repairing a computer for a friend. When I start the computer I get a continual short beeps. I have checked connections but nothing shows bad. The computer worked fine previously and I haven't...
depending on the number of beeps and their durations you can search your motherboards bios beep codes which should tell you the general area of the fail
try unplugging and re-seating memory cpu videocard / monitor
these are the usual main culprits
May 06, 2011 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Aces Aspire M1640 desktop-pc starts but the monitor says NO SIGNAL. Tried various monitors and videocards without result. Can't find what mainbord is in it to have it changed. Regards, Toine
black out can be caused by series of things. Power supply is one. Second is the motherboard, memory and the processor aside from the video card. Motherboard and processor can be isolated,first is to remove the rest of the devices such as hard disk and cards and memory. Beep sound means your board is still doing fine. Re install all the devices and power on again. Good luck
Sep 12, 2010 | Acer Aspire M1640 Refurbished Intel...
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
I tried to install a new motherboard but it didn't work
Your bios needed to be set with the correct memory speed on your old motherboard or it did not support the memory you added or it was in the wrong memory slot or size. The beeping was telling you it was a memory error. I need more info such as processor and memory speed and type to help. What is your old motherboard? It sound like Bios settings but I need to make sure the memory and processor will work with *********** board.
Jan 16, 2009 | ASUS P4B266-C (P4B266-C WA) Motherboard
Amd 2800+
tried another motherboard ? that will tell you if you git a burned processor
Sep 09, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I have no beep code
hi, sam
please confirm that there is no problem with ur machine (cpu cabinate) by checking it. please start ur machine the press num lock or caps lock on ur key board if nums or caps light on or off is working then it means ur machine is ok. if not then please remove ur cmos bettary from ur mother board & then start ur machine. i think it will resolve ur problem.
hero302
May 05, 2008 | ASUS K8V-MX Motherboard
Hi melnavz,
Hello Mayfield.
Since that your computer is still booting. the processor, memory is good. The only problem you encountered is cannot hold the time when you totally unplug the unit to the wall. iN that case, maybe something wrong with your mboard. maybe there some connection or jumper that was unnoticeally remove which make the battery open circuit. Please refer to the manual of the maboard for some jumper setting.
melnavz
Mar 14, 2008 | ASUS P5RD1-VM Motherboard
No screen, no boot, only the power LED flash orange
In this case you should examine the motherboard and the processor.
verify the Mboard maybe maybe some part oversheat, if non then , Kindly remove the processor, then switch on for a while then shutdown: fix back the procesor and then switch on. still no beeps? try your Processor to other computer system with same socket on mainboard. if the processr work; then your mainboard is damage. u need to replace; if not work. processor is damage and need to replace.
Be sure to test all the pheriperals of your system before you buy a replacement to see if some other parts is no problem.
Like memory, VGA,
If all of the solution is not working its time u to assemble new computer system. i give you all the possible solution, or else tell me the working part i will help you seeking and speicy the replacemnet part.
thank you more power.
Jan 29, 2008 | Acer Aspire 3680 Laptop
About my pc's configuration
amd i live get amd x 6400 with 4 gb ram to start nice asus mobo and a 8800gtx video nice power suply with it and mide size case with alot fans ok u can pplay any game get parts on newegg.com all for under 500
Jan 23, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
ASUS Intel 850 Chipset P4T-E (P4T-E/WOA) Motherboard Logo
1,650 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
