Question about Philips Magnavox 9P6034C 60" Rear Projection Television
No screen, no sound, only the green light at the front of the set on.
After the set was on for a few seconds the screen would go small, the sound would still be there. Now there is no sound nor picture now. Please help
Model 9p6034 9103
Chas: PTV835
Date:9/22/00
  • teklady Jun 08, 2008
    June 2008.
    Same problem happen yesterday. High voltage reads fine all the way through. No lamps will light/turn on. I have tried multiple inputs. Convergence allways stank but at least it worked. Husband thinks the tube may be bad.
    Teklady@tampabay.rr.com
Replace IC7412 - - - - 6N136.
Posted on Nov 21, 2011
If you are familiar with electronics and how to repair it, look at the circuit from the bottom to see any discoloration or burn close to diodes. Most likely D2539 had gone out if there was surge protector. If you know a way to test the flyby or transformer, I would start with diode first and gradually test others.
Good luck
Posted on May 27, 2008
  • Philips Master
  • 5,138 Answers
There is alot of things that would cause this -shorted hori out put leaky or bad capacitor,you are looking at repair cost anywhere from 250.00 and up.also this set is famous for bad convergence broad & weak tubes!
Posted on Jan 26, 2008
  • Philips Master
  • 3,459 Answers
Problem solved.
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Posted on Jun 20, 2008
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
Phillips Magnavox 9p6034c 60 in. rear projection t.v.
are you sure!? or maybe you set at the pip viewer! go to settings!
Oct 01, 2007 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
THE TV WILL NOT POWER UP
It depends on a lot of other things, but you could try these steps . . .(assuming its a TFT flat screen)
Has the mains fuse blown ? try a different mains cable.
If it works from a power supply/mains transformer (a small box attached to the mains supply cable), check that box - they usually have a small green light on them to show they are getting power. These are easily replaced if that part is faulty.
Has the power cable come detached from the rear of the TV ?
Does a power light appear on the actual TV front (usually blue or green), and then go red (or off) after a few seconds. In that case the screen has a more hard to fix problem inside :(
Apr 04, 2010 | Sylvania LD370SS8 37 in. LCD Television
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
No Picture, cannot power off without unplugging, flashing green light
The part is Replace an X-tal (Viper) on SSB item 1H00, order code: 242254301397. The small small signal board is the one with the video jack on it. It mat be easyer to replace the SSB but yes it will cost more.
Oct 09, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Magnavox 9P6034C 60 in. Rear... Problem
I had a similiar problem. My screen would shrink in then expand. After a few months of doing this it just broke altogether. No sound or video.  Its not fixed.
You can get a repair kit from this site.
http:///www.magnavoxhelp.com
Sep 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
164 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
