Question about Hotpoint First Edition FEW12 Front Load Washer
De dietrich oven
Hi, how do i replace my oven door hinges
  • Danny Dankner Oct 12, 2008
    I'd like to replace the door hinges in my oven. I could not take the current ones apart.
    The oven is De Dietrich type cd3247f12. I assume it must be some 10 years old.
    I attach a couple of photos. I would greatly appreciate if you could provide me a tip of how to take these apart and replace them with new ones.
    Thanks!
    Novelist:
    Champion:
  • 244 Answers
Is this for oven hinges or washer hinges for a first edition m8
Posted on Jan 27, 2008
How do I access the fixing nut on a loose handle on a De Dietrich DME 795x oven.
not so easy
gee ...thats a glass front pull down frame
the user manual
page 8 shows the door but no disassembly of the frame
if no screws to get into the frame and loose screw
..might have to buy the whole door
DeDietrich DME795X Instructions For Use Manual Description Of Your...
Jun 01, 2016 | De Dietrich Ovens
Oven door doesnt close well
I'm not familiar with your oven but most oven doors are very similar in operation. When the door doesn't close well it's generally because the hinges have been stretched/bent when the oven door has been open. To see if this is the case, open the door fully. If it's stretched the door will open past 90 degrees (slope down instead of being horizontal). The easiest way to fix this is to bend it back. Place something as a spacer between the door and the oven on both sides (like a spanner handle or anything strong and about 8mm thick) as close to the hinge as possible. Close the door against it carefully and push the door closed. Do it a little at a time and remove the spacers and try the door each time until you are happy that it closes nicely again. It should be spring loaded closed slightly.
Aug 14, 2013 | De Dietrich DOC310 Electric Single Oven
De dietrich oven clock tripping out
I already explained, you need to replace the big 1.5uF Capacitor that
is reponsible for the voltage drop from 220V to about 10V. You need to
remove the timer controler module from the oven, in the meanwhile you
can shunt the 2 wires that usually are shunt by the relay, and then
buy a new capacitor and replace it with a soldering iron.
Good luck.
Apr 11, 2013 | De Dietrich DOC310 Electric Single Oven
N Serie: 04-09-01097 Ref DOD 348XXG11 Type E248H1 52106 The above are the details of my De Dietrich oven. My fan has stopped working and I need a new seal for the main oven door and for the...
We don't offer service engineers. Look in yellow pages or ask your oven supplier for a contact. Most Domestic Appliance companies can help you.
Sep 25, 2017 | De Dietrich Ovens
Light stays on in De Dietrich oven DOD438 all the time. It is in the lower oven. Stays on whether door is open or closed. Oven is new since May 2007
I too have just had this problem. The door switch (top right corner) is broken and the oven thinks the door is always open. Chances are it won't heat up either.
Apr 05, 2010 | De Dietrich 22 in. DTV315 Electric Cooktop
De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Dec 11, 2009 | Ovens
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
Hotpoint First Edition FEW12 Front Load Washer Logo
62 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
