Question about Braun Syncro 7526 Electric Shaver
Replacing the drive unit
The drive unit 7/12 needs replacing, how do you dismatle the shaver to do this?
  • Anonymous Mar 13, 2009
    Yes but how do we put the spring and the plastic lever back in the shaver. We need a schematic of some sort...please
    Problem Solver:
  • 5 Answers
Replace the drive unit yourself it is easy
Buy the drive unit $25:
http://shaveroutlet.com/braun-other-parts-c-4_27.html
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace drive unit
7) Reasemble
Posted on Jan 07, 2009
    Novelist:
  • 124 Answers
Generally good directions supplied by chriswest, but I'd like to clarify a little.
*) Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert a thin metal nail file or other thin pointed object with smooth edges into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
*) When reassembling, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way--very frustrating. I've found that it's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
*) Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
*) Be careful of the pressure clips on the sides of the unit once the silver trim is removed. They're very peculiar in that they bend very easily out of shape and can't be bent back to the way they were without taking them off (which is an annoyance).
Posted on May 23, 2009
  • Gary
    Gary May 23, 2009
    Opening a Braun 7000 Series Shaver
    1) Find a thin metal object with no sharp edges (such as a nail file). Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert the metal object into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
    2) The silver side parts are held on by two tabs at the top. With the bottom piece gone, the side parts swing off easily. Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
    3) The case is held together by 4 small torq screws. Use a torq screwdriver--do not attempt to do this with anything else. Be careful to turn the screws slowly, so you don't strip them.
    4) With the screws removed, the two halves of the shaver will come apart. The remaining parts can be extracted without any special tools. Keep note of how they are removed, as assembly will be the reversal of removal.
    5) Note that if you are replacing the batteries (there are two of them), you will need a soldering iron to detach them from the circuit board, unless you're replacing the whole part.
    6) Reassembly is pretty much what you expect--the reverse of disassembly. However, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way. It's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
6ya staff
SOURCE:
I have a Braun 7570 and it is marvelous! I replace foil and cutter every year. This time after replacing it the shaver did not cut my hair. Battery still gets full charge. What is the problem?
Most likely, the 'drive unit' is bad. The drive unit is a component that consists of the swivel frame that the head snaps onto and the motor. Excessive noise while the shaver is running is also a major sign that this part is bad.
Unfortunately, Braun no longer provides these type of replacement parts for any of their shavers. You may end up needing to replace the unit.
Since you apparently like that model and you have spare shaver heads for it, you might want to consider a compatible model as a replacement. shaveroutlet.com has a new model that uses the same foils and cutters as your 7570. You can see it at the link below
http://shaveroutlet.com/shavers/foil-shavers/braun-series-1-195s-mens-cordless-shaver.html
Feb 19, 2014 | Braun Syncro 7570 Electric Shaver
I have the Braun 9595 and believe my motor/drive unit need to be replaced. I have read that even if I purchased the part myself, I would not be able to remove the old motor and install the new one as the...
DC motors usually do need to aligned to controllers however, with electric shavers they are usually sold together as a "drive unit." Now as far as your shaver goes, I could not find a replacement drive unit and what I did find showed that it was discontinued. Sorry. Braun 9595 5671 Pulsonic Parts
Nov 28, 2017 | Braun Activator 8595 Electric Shaver
Excessive vibration with Braun razor
Most likely, the oscillator in the drive unit is broken. You will find this part for model 7680 at shaversource.com. See link below for product and helpful disassembly video
http://shaversource.com/shaver-replacement-parts/braun-7000-series-syncro-motor-drive-unit-p-110.html
Jun 09, 2011 | Braun Syncro 7680 Electric Shaver
When I power on to the first setting(shave head pivots) it makes a very loud noise like the insides are loose. On the second setting(pivoting head locked) it gets quite a bit quieter. and if I hold my...
You will find a video for disassembly of the shaver at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
However, I seriously doubt that tightening anything is the problem. More that likely, the oscillator inside the swivel frame is cracked and causing the sound. You will probably need to replace the drive unit. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-motor-drive-unit-p-110.html
May 24, 2011 | Braun Syncro 7526 Electric Shaver
Shaver is getting very loud
Most likely, the swivel frame that the foil snaps onto has a broken piece(s) of plastic inside making a buzzing sound. If this is the case, you will need to replace the drive unit. You will find this part for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Disassembly video can also be found at shaveroutlet.com. See link below
Jan 07, 2011 | Braun 8585 Electric Shaver
Shaver started making a loud vibrating noise from blade and foil
Most likely, the drive unit needs replacing. You will find a drive unit at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
To replace you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out
Jun 11, 2010 | Braun Syncro 7526 Electric Shaver
Loud rattling noise
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
May 10, 2010 | Braun 8585 Electric Shaver
Braun Drive Unit 7030244
To open the shaver, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
You will find a replacement drive unit for model 8585 at shaveroutlet.com. See link below
Apr 07, 2010 | Braun 8585 Electric Shaver
Braun 8595 vibrates excessively and sometimes jams
I'm in the process of replacing the Braun 8000 Series Activator Motor Drive Unit in my shaver. The Motor Drive Unit is all one piece, cost $33.99 at http://shaveroutlet.com/.To disassemble remove the plastic cover on the bottom that covers the cord socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I used my fingernail to create a space big enough to insert the corner on a credit card in the center of a long side and gently removed the cover. Using a screwdriver could damage the plastic. The two sides then pop off. There are a total of four screws holding the body together. Remove the screws, the shaver splits into. Remove the Motor Drive Unit and replace with new unit. There is also a circuit board with the batteries below the Motor Drive Unit. Assembly is the reverse of above.
Nov 25, 2008 | Braun Activator 8595 Electric Shaver
Very Loud Since Replacing Cutter Block
Open the shaver:
4) Open shaver
7) Reasemble
Oct 11, 2007 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
161 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
T.Johns
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
