Question about Vacuums
Dyson dco5 Pulled the unit too hard to get extra flex. The plug is ok changed the fuse. I believe the cable has detached itself from the inside. How can i check the inside of the unit for cable damage
  • 372 Answers
Try this site has manuals on replacing mains rewinder unit on Dc05.
Posted on Jan 26, 2008
Dyson upright vacuum with kinked cord kept stopping. There was a loud bang and smoke and the vacuum stopped. Has the motor blown up, or can it be repaired?
This happens a lot the supply cable bending or damaged shorts out causing smoke and a bang if fitted with or backed up with a high amperage fuse .
check length of supply cable if you find damage/ burning smell,
either replace cable, or you could fit a inline rubber socket and plug by cutting out damaged part of cable and fitting female part of plug first into supply cable 1. then on the vacuum side of cable fit the male part of plug 2 . supply 1. -----o o----------2.--- vac
using insulation tape if you like you can tape plug and socket together to stop it pulling apart, normally cable damage will not damage the vacuum cleaner. and fit the correct fuse rating for the machine 1000 watts at 240v divide 240 into 1000 =4.166 amps
so with a 1000 w load you do not need a 13 a fuse fitted 6 amp fuse should be ok. or go online and see what is recommended re fuse size for appliance ,
Nov 12, 2016 | Dyson Vacuums
Dco5 burning smell not working
Hi there, it's Jack at Dyson.
If your DC05 is making a burning smell, it sounds like it may be the motor that's at fault. DC05 is one of our very oldest machines, and unfortunately since the start of 2015, we have no longer been able to support DC05 with spares or servicing due to its age. However we do have some discount offers available so DC05 owners can upgrade to the latest Dyson technology if they choose to do so.
If you'd like to find out more or discuss your options with our experts, you're welcome to call us on 0800 298 0298 (UK), or 1800 239 766 (AU).
Feb 10, 2015 | Dyson DC05 Cylinder Bagless Canister...
My dyson dc14 when you push the start button doesnt turn on? could the button need replaced
The most likely fault is a break in the cable near the point where it enters the machine, if cable is ok it could be the switch, or it could be a fuse in the plug if you have fused plugs. Get someone to check the cable, often the broken part can be removed, and you end up with a slightly shorter cable by about 20cm
Jul 15, 2014 | Dyson DC14 All Floors Upright Vacuum...
I was using the Dyson, turned off to empty tank, will not turn on again, I have checked outlet it is ok. Does it have some kind of safety if it gets to hot.Thanks
there is a thermal fuse built into the motor of all dysons that will cut the power if the motor gets too hot.
when the motor cools down again, the fuse will normally reset itself.
try the hoover again after a few hours and see if it works again.
also change the fuse in the plug to check that that has not blown
Apr 03, 2011 | Dyson Vacuums
Our upright Dyson has just stopped working. No
There are four possibilities:
1) If in a country that has a fused plug, the fuse in the plug (unlikely). 2) The switch (unlikely). 3) A break inside the cable that you cannot see (quite likely). 3) The motor is shot and needs replacing (very likely).
Jan 10, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Plugged my Dyson in this morning, switched it on and power came on for not even a second and died. No power what so ever to dyson - checked my house sockets, changed fuse. Still not working - dead as a...
It is either your power cable, cable rewind mechanism or your motor.
Try switching it on, and wiggling the lead near the plug and see if it fires up. If it does, remove the moulded plug and fit a standard plug.
If not, likely suspect is the motor or the cable rewind mechanism. Neither are an amateur job. If you are in the UK, you could send it to Manchester Dyson for either to be fixed. Carriage will cost you about £10 each way. A motor replacement will cost around £65 and a cable rewind mechanism about £45-£50.
Nov 25, 2010 | Dyson DC08 Cylinder Bagless Canister...
Dyson DC 25 Dyson Ball animal. The bottom brush is not rotating. I detached as and reattached as the manual suggested. Help Thank you very much
Two things you can do. 1- Remove the brush as if you were going to change the drive belt for it. Clean the brush as best you can and spray some WD40 on the hard rubber/plastic pieces at both ends of the brush. Rotate the pieces to work the WD40 into the space between the pieces and the brush axle. 2- If you have one available, as long as the brush is off, change the belt.
This should get your unit back in operation. If you find this solution helpful, I would appreciate a Thumbs Up from you. Thank you. Paul
Oct 08, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My dc 05 isnt working and i cant understand why , i have cleaned all filters etc and i also changed the fuse on the plug , which after i didi that it attempted to start but then jus cut out again so i...
Most common cause of this problem is a wire broken inside the flex, usually either just where it leaves the plug (easy to fix) or at the other end (more of a problem). In either case, this is no reason to dump the machine - it can be fixed at a fraction of the cost of a new one.
If you need guidance on what to actually do about this, post a reply here, saying what country you are in please.
Feb 17, 2010 | Dyson DC05 Cylinder Bagless Canister...
My DC05 does not switch on. I have checked and confirmed the fuse is ok and washed & dried the filter
You can sometimes tell from the "feel" of the switch if this is a problem with the switch itself. However, by far the most common cause of the "won't switch on" problem is damage to the flex. Dysons are often let down by the quality of their flex, and it's quite common for the copper wire in the flex to break (compounded by the fact that the plastic tends to become brittle, especially if the flex has not always been fully unwound in use). This usually happens where the flex is subject to the greatest strain and bending - where it leaves the plug and at the other end which (sadly for a DC05) is inside the rewind reel. There may or may not be visible external signs of damage.
If you want to know what's involved in fitting a new flex and reel, go to then scroll to the bottom of the page and click on "DC02 cable replacement". The person who set up that site hasn't done a page for this job on a DC05, but the DC02 is similar. His "DC05 motor replacement" page shows you how to dismantle the 05 and get to the cable reel.
I hope this helps. Good luck!
Feb 14, 2010 | Dyson DC05 Cylinder Bagless Canister...
Vacuums Logo
128 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
